Question about DCS Kitchen Ranges
Oven controls do not match actual oven temp - DCS Kitchen Ranges
  • 3,083 Answers
This sounds like a thermostat problem. The following website tells you how to check it and gives general directions for replacement:
http://www.ehow.com/how_112247_fix-electric-oven.html
If you enter your model number at the following website, they may have diagrams and parts lists that can help you (they have them for a lot, but not all):
http://www.appliancepartspros.com/
Good luck, and hope this helps get you fixed up.
Posted on Nov 09, 2010
  • Janis Countiss Jul 08, 2013
    Did you get your thermostat fixed on your DCS?
    appliancepartspros.com does not carry DCS Thermostats for the 36-6-1 as far as I can see.
Oven heats too slowly, and temp on thermostat does not match real temp in oven
Hello Henk Rietveld - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 09, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire freezer temp says -12 degrees
If the inside temp does not match what the display states, then you have a control board issue. If it does match you have a coolant issue.
Aug 05, 2012 | Frigidaire Professional Series PHS68EJSB...
We have a Whirlpool gas range model SF379LEKS that was purchased new in 2004. The oven heats up at first but then stops heating, even though the display says it's still on. There are no error codes. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 03, 2011 | Ovens
The temp. setting doesnt match the actual temp inside oven
Without more info i can only give general info. ISOLATE MAINS POWER BEFORE REMOVING PANELS
It sounds like one of several possible problems, temp control switch they use in some models two terminal over heat control components, or temp prob, the first type is a metal case with two terminals, you may see black on this if not a test meter will be required. It should conduct through the terminals, not the case to the terminals, Impedance setting low on meter. The second type is a bit tricky to test and is generaly controlled by an electronic circuit, it is poss it could be one element blow inspect them a Black Grey spot blow out or a bulge on the element surface. This can cause temp problems.
Hope this has been helpful
John
May 20, 2011 | Kenmore Ovens
Whirlpool range 465 model # sf369lemo oven temperature
no stove holds a true temp they all fluctuate temperature depending on how well it is insulated.
Feb 06, 2010 | Kitchen Ranges
Oven Control indication (temperature) and actual oven temperature do not match. Is there an adjustment? Vulcan Commercial Gas Range
needs calibrated. put oven thermometer in oven, turn on oven. adjust dial to temp on thermometer by loosening nut behind dial, then replace dial, turn to temp, re-tighten nut
Oct 26, 2009 | Kitchen Ranges
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Aug 04, 2009 | GE Ovens
F-2 code
HI. this code can come up for two different reasons. it could during a bake session or a cleaning situation as well. I will list the details below.
During Baking(((f2)))
During a baking session, if the control senses an active oven temp above 615f-630f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
During Cleaning(((f2)))
During a cleaning session, if the control senses an active oven temp above 915f-930f, this code will appear.
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Aug 02, 2009 | GE Ovens
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
Kitchen Ranges Logo
206 people viewed this question
Top DCS Kitchen Ranges Experts
Carmen Mikulic
John Tripp
John Tripp
Paul Carew
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
