Question about Aiwa Audio Players & Recorders
I have a stack system consisting of FX-A120 cassette, TX-80 tuner, GX-120 Pre amp, and BX-120 Pwr amp. there are lights on all systems. I get no sound out of the speakers.
  • 4234 Answers
SOURCE: help urgently required.....
The click you hear is the power relay. Normally that would be followed by amother click of the speaker relay. In this case, the output section is in protect mode because of a fault detected. This will prevent the speaker relay from turning on the speakers. This amp will require repair. I don't recall your specific model, but if it has discrete transistors, expect a parts cost in the $20 range. If it has a single output amp pac, then the part could be in the $65 range. Add in the local labor rate for the complete repair cost.
Dan
Posted on Apr 02, 2008
  • 319 Answers
SOURCE: Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
Posted on May 07, 2008
SOURCE: Microsoft Digital Sound System 80 - Parts
Same here!
Silicon seal fixed for a while ... ripped again 3 months later.
Posted on Aug 30, 2008
SOURCE: I have a Harman Kardon
want to buy a 710 with a 750 amp in working order
contact mikris2000@hotmail.com
Posted on Sep 06, 2008
  • 165 Answers
SOURCE: tx-38/28 quartz synthesized tuner amplifier
hello surely there,s a problem in connection firs do this check your jbl even if they new with a baterry they pop up,now make sure you connect the monster wire into the outputs remember the wire is too thick make sure your getting contact in outputs...saludos
Posted on Nov 27, 2008
How to conect red and white cables from tuner t4150 to pre amp p304 to eq 540 t0 cassette deck ta 2600 thank you
Normally your tuner is your preamp and then you go to the amp. Exception being is if it is just a tuner. That being said you should have a left and right in on your preamp that will accept your cassette deck, out from your cassette deck to the in on your tuner. out on your tuner to the in of the amp. Red is right and white is left on audio cables.
Jan 18, 2016 | Audio Players & Recorders
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
I have an Akai stereo system Sound processor EA750 Tuner pre amp TP750 CD player CD750 Amplifier PH950 Cassette Player HX950 When I switch on a notice appears "Error" I cannot find...
Since you have so many items in your music system, it is the correct connection that matters. Any wrong connection (sequence wise) will give errors. So, follow the instructions that came with each one of them.
Dec 06, 2010 | Audio Players & Recorders
How do I factor using the fx-115 ES calculator? would a problem like 9x^2+24x+16-Z^2 be solvable on this calculator? If not, does Casio sell any calculators that would help me factor this equation?
No, your calculator cannot factor polynomials. You need a calculator that has a CAS (computer Algebra System)
Yes Casio sells calculators with CAS: The FX-Algebra 2.0 and 1.0, the FX-9860GPLUS/GII SD, the GRAPH85 or 80 and the Graph 100+. You also have the CLASSPAD Series 300PLUS and 330.
TI and HP also have CAS calculators.
Texas Instruments
TI 89 /Titanium, Voyage 200PLT, TI92PLUS (discontinued), TI Inspire CAS.
Hewlet-Packard
HP 48G/G+/GX, HP40G, HP49G/G+ and the top of the line HP50G
Oct 28, 2010 | Casio FX-115ES Scientific Calculator
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Re: Technics HD51 home stereo system (amp, tuner, CD, and cassette player) - I'm told it needs a pre-amp in order to get any reasonable amount of sound out of lp's on the Linn Sonex LP12 turntable. At the...
The Amplifier must have a high impedance input for the turntable to be connected. Now most of the present day amplifiers do not have this input but only the regular aux input which is designed for a larger signal . But the turntable outputs is quite low and so it requires an amplification of high order. What you can do if you need to play the turntable is to have first a preamplifier with a high impedance which is available even inkit form and can be fitted on to your system. The preamp output can be shared into the input of the source selector maybe with a switch and you willl be able to fix two RCA sockets to accept the input of the phono. This will work fine provided the shielding is done well to avoid the high feedbacck to oascillate and cause noise, the premap must be housed in a shielded cabin. On the other hand you may have to buy a universal amplifier so that the phono input is present. Definetely nothing better than a designed input. So think and decide. hope I could help; Good day
Aug 10, 2010 | Technics Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Instruction manual
Trying to use the computer controlled JVC AM/FM Tuner Model FX-333.
I am attempting to use the pre-set stations desired for listening pleasure, but I have not been successful. Can you help me?
The FX-333 Tuner is linked to the AX-R441 Amp.
May 22, 2008 | Audio Players & Recorders
148NW ST No TX AM or SSB
finals need to be replaced, as they are fried,, hence no output,,and if you are lucky you haven't fried the pre-amp as yet....as the pre amp is REAL EXPENSIVE....so stop keying it up
Jul 27, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
122 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
