Question about Hydro Slide NQD Hydro Speed Radio Control Boat
Hello, I have a NQD 30"Hydro boat Model # 757 t
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : steve1995z@hotmail.com.
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 | Boating
I am looking for a wiring diagram for a 1972 Boatel Islander. My wife bought this boat 3 years ago. It is sea (or rather lake) worthy (after 1000's of dollars). At this point, most of the work is...
When we had to replace a wiring harness in that era, we made a diagram of connections and colors, (today we have phone cameras) Then we had 30 different color wire and different sizes for load. We would pull the need amount of wires and some extras and tie a harness long enough to fit, plus a lot of extra. Sleeve it for chafe guard and reconnect. Not as hard as it sounds. The was not much uniformity in those days. Good luck.
Mar 20, 2015 | Boating
Have zt2560 runs good, but after running about 30-40 min. seems like the hydro starts getting weak, let it cool down for a while runs great again for a while, is there a filter or something i should be...
My name is Dane and I am going to try to help you solve your problem. I've done a little research on this mower and I believe your problem could be your drive belt. Swisher Part number 6046 which is a 47" belt. I have found your operators manual at the following link:
http://www.swisherinc.com/manuals/PDF/ZT/ZT2560.pdf
I didn't know if you had the 06-046 model or the 07-152, but the belts are the same for each. Once a belt becomes worn they will give the symptoms you are discribing. You can replace the belt per this manual and all should be well.
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Dec 05, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Ther are 3 wires disconded 2 are from to on off swict and the other is the antna wire dont know where that gose..I would like the skamtic and it would be fixed....
the best thing to do is bring that toy to ur nearest electronic technician and look where the disconnected wire could have been soldered! By looking at the board u might where it came from, the other wire should be in the POWER( + ), as you said it came from the SWiTCH! The other one, antennae wire must in the ANTENNAE itself! You got only 1 wire w/c is the main prob. that goes to the circuit board! Taah!
Nov 10, 2010 | Hydro Slide Speed Storm Radio Control R/c...
I have a Lowe 24' pontoon boat ,I need the wiring schematics or diagram to rewire the lighting system..
go to the website for lowes boats and request a pdf version of the wiring for your model of boat. good luck. unless the wiring was removed or disturbed you should be able to follow the existing wiring to solve your problem. you also might find another boat like yours and look at the wiring at a marina and take notes. get permission first of course.
May 30, 2010 | Boating
I need a diagram for wiring for a 1986 Ford Bronco with a L6-300. Can you help me find one?
Do you still need a wiring diagram, I have on that I can scan and email to you. hiplaces@yahoo.com 757-943-1224 cell 757-204-7274 home
Apr 15, 2010 | 1986 Ford Bronco
Hydro Slide NQD Hydro Speed Radio Control Boat Logo
103 people viewed this question
Top Hydro Slide Toys Experts
ray gallant
Are you a Hydro Slide Toy Expert? Answer questions, earn points and help others
