Question about Vtech 5.8GHz Analog Cordless Phone
Replaced battery [with correct battery] Phone charge light is on but phone won't work--nothing on LED panel
    Problem Solver:
  • 5 Answers
Return it where you purchased it.
Posted on Nov 09, 2010
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
The phone won't turn on
Try replacing the rechargable battery inside that phone.
Jan 12, 2013 | HTC Amaze 4G Smartphone T-Mobile
My blackberry 7105t won't switch on even battery is ok. i even tried charging it with different charger and connecting it to pc yet nothing happen--blank screen & led light not lit.
Hi there. It sounds like the USB connector has broken off the phones motherboard. You can order a replacement part from www.cnn.cn and replace it yourself. You're looking for the USB charging port. If you're not comfortable taking apart the phone and soldering, your best bet is a new phone. Alex
Jun 30, 2011 | Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
My w980 just switched-off. I've connected
when you turn your phone on only the keypad lights up right? or nothing happens?
if nothing happens charge your phone til red led on side turns off
after that please continue to read
its a w980 software problem, very common
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
please note this will restore phone to factory state
Dec 22, 2009 | Sony Ericsson Walkman W980i Cellular Phone
My Insignia NS-BTHDP headphones don't have a red charge light anymore. The first charge out of the pack had the red light on. But now the red light doesn't come on anymore. I wonder if it is really...
The LED may have just gone bad. Keep using it untill the battery dies, then try charging it and use it again. If it works as it should it means the LED died and there is nothing to worry about, if not you may need to replace the battery.
Jun 16, 2009 | Insignia Bluetooth Wireless Headphones...
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
Vtech 5.8GHz Analog Cordless Phone Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
