Two of theconnectors are burnt - Heating & Cooling
  • 81 Answers
What colour cables are they?black/brown red/blue? does the unit still work .it might have just water/dust across the terminals
Posted on Nov 09, 2010
Half keys stoped work
the ribbon cable to your keyboard has come loose fron theconnector on your motherboard
Feb 04, 2013 | HP ProBook 4710s Notebook
Sense key=0x4,asc=0x48,ddes=0x88
Hello Adil,
Does your scanner display H0/H8 alarm?
Does the same symptom occur after turning OFF and ON the scanner?
Does any foreign object get inside the Control PCA? Check the control PCA.
Are the cables between Control PCA and the motor damaged? Or are the
connectors connected correctly? Check throughly.
If the issue is not resolved, then you may have to replace the Control PCA as the motor fuse is located in the control PCA unit. For replacement you are recommended to contact Fujitsu scanner expert.
Thanks,
ScanCare
Jan 22, 2012 | Fujitsu fi-6130 Flatbed Scanner
Hp 3600 fuser error 50.9. I have replaced the fusing unit and it worked for a day or two. Any suggestions appreciated. copyguy69
50.9 Error:1. Verify the fuser is installed correctly andfully seated.2. Check that connector J6007 on thefuser is seated correctly. Replace theconnector as necessary.3. Turn off the printer.4. Remove the fuser.5. Measure the resistance between fuserconnectors J6007LA-2 and J6007LA-3.If the resistance is not 100 kohms to3 Mohms, replace the fuser.6. Replace the DC controller PCA.
Oct 07, 2011 | HP LaserJet 3600n Printer
1. Turn the printer off and allow
it to cool down.
2. Reinstall the fuser, and check
the connector (J100) that
connects the fuser and the
printer. Replace the
connector if it is damaged.
3. Turn the printer off and
remove the fuser. Measure
the resistance between the
connector pins on the fuser. If
resistance does not meet the
following guidelines, replace
the fuser.
J100LB-5 to J100LB-6: 300 -
500 KOhms
J100LB-1 to J100LB-2: less
than 1 KOhm
4. Check for continuity between
connector pins J100-5 and
J100-6. If there is no
continuity, replace the fuser.
5. Replace the fuser power
supply PCB.
PCB. Calibrate the printer
after replacing the DC
controller.
Its usually the fuser when this error pops up though and heres a good place to get it pretty reasonable
FUSER Click Here
Sep 12, 2011 | HP LaserJet P4015 Printer
Have several Sabrent 3.5 Hard Drive Cases that I cannot use For SATA Drives! .ONE IS A CASE WITH INTERNAL SATA CABLE WHEREIN THE CABLE ISLIKE A TRANSPARENT LAMP CORD. The pilot light does not go on so It...
In many of these cases, you can replace the internal data cable on the hard drive cases with a separate cable - I did that for two hard drive boxes that I owned, both of their IDE cables somehow "stopped working" after a year or two.
I'd recommend buying something like this to fix it:http://www.amazon.com/iMicro-240149-SATA-Data-Cable/dp/B001O4EPHA/ref=sr_1_1?s=electronics&ie=UTF8&qid=1293046024&sr=1-1
Also, in the future, Sabrent isn't a good company - I spent $35 and got an Ultra converter.
Right now it's down to $25 - and it's a very high quality piece - I strongly recommend it:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554&CatId=3770
Dec 22, 2010 | Computers & Internet
Electrical connector
Go to the Jensen Website and call up their technicians they might sell you a radio harness for like $10- $20 Most retailers won sell you a harness for each radio has its own and no extra. Or you can try to find a broken similar Jensen radio and unplug its harness or go to Best Buy roadshop where they install radio's and they may have a spare jensen harness.
Apr 05, 2010 | Jensen VM9510 Car DVD Player
To replace broken screen on acer aspire 5735
First you need to get the right screen. Take out the screen by removing the rubber bumpers on the corners of the lcd bezel, then unscrew the screws that were beneath the rubber. After that you will have to pry slightly on the edges of the bezel to unsnap it and remove it from the laptop.
After that you will remove the screws on the sides the attach the screen to the hindges. On the back of the lcd it will give the model number, ebay is a good source for lcd screens. Once you get a replacement screen, you disconnect the cable on the back of the lcd and bottom, and then repalce the screen and assemble in reverse order.
Sep 01, 2009 | Acer Aspire 5735 Notebook
I dropped my sony ericcson walkman
there is a loose connection or a broken signal path to the lcd..have a good technician fix it if it is still worth the fix
Aug 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Need to remove lcd
Hello
These are the tips you should follow. This is my solution regards about my laptop problem.
You replaced the broken LCD screen in your laptop with a new screen but it’s not working. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible withthe old one. Different screens require different video cables. Makesure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in yourlaptop. A part of the screen still works fine but you cannot use itlike that so you decided to replace the screen yourself.
screen-not-working-1.jpgYou did some research and purchased a compatible screen, installedit into the laptop, turned it on and… The new screen is not working!!!What could be wrong?
Before you start to panic, check all cable connections again. Checkconnection between the video cable, LCD screen and inverter board.Reconnect cables just in case.
screen-not-working-3.jpgTake a closer look at the connection between the video cable and LCDscreen. It’s possible you accidentally pulled the video cable from theconnector during the screen installation.
screen-not-working-4.jpgThe video cable has to be seated properly, all the way down.
screen-not-working-5.jpgAlso, on some older LCD screens there are very thin pins inside theconnector. Take a look inside the connector, make sure there are nodamaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
screen-not-working-6.jpgOK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one worksproperly (except the damaged area) but the new one is dead, apparentlythe new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverterboard and plug in the old screen instead, as it shown on the picturebelow. If the backlight inside the old screen lights up, apparently thenew screen has defective backlight lamp and has to be replaced.
Good luck !!
ICmanServer
Jul 09, 2009 | Computers & Internet
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
