Question about Hampton Bay 24002 Ceiling Fan
I have a Harbor Breeze (Lowes) ceiling fan for which the light portion (but not the fan) recently stopped working... I opened the lighting section to find a wattage limiter device in which a small, soldered on, fuse had blown. We recently had a voltage spike in our house do to a blown power transformer on the outside power lines... I'm guessing this was the cause. I inspected the rest of the wiring and saw nothing else wrong. I have been unable to find a replacement part for this limiter though... would there be any real issue to simply removing the limiter and bypassing it? The fixture uses 3, 35W bulbs, so it shouldn't use more than 105 watts anyways....
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Posted on Nov 25, 2008
Buffalo12980
  • 625 Answers
SOURCE: MAXIMUM WATTAGE FOR FAN LIGHTS??????
those bulbs are candelabra type. if they came with the fixture then I wouldn't go to a higher wattage bulb. the sockets are probably bakelite and mounted with the base up so any heat off the lamps would be directed upwards. higher wattage bulbs may shorten the lifespan of the sockets. bakelite is a modified plastic. it won't melt but it will get brittle.
Posted on Aug 22, 2007
  • 4 Answers
SOURCE: Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Posted on Jan 07, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
  • 4 Answers
SOURCE: harbor breeze ceiling fan
Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Posted on Nov 21, 2008
Need a Harborbreze globe for our 52" Summit Polished Brass Ceiling Fan. Tried Lowes and don't have them.
Fixya does not sell Harbor Breeze parts. Rather curious that Lowe's cannot supply the globe because Harbor Breeze is a "house" brand.
Jul 08, 2016 | Dryers
I broke a shade on my harbor breeze lighthouse II ceiling fan, will you find the model number so I can order one?
Wrong way round, YOU tell us the model number and type and we tell you where to get the shade. You can see the fan in your house, but we can't. That makes it really difficult for us. Some shades are plain, some are fluted, some have patterns.
All is not lost though. Go here and take your pick. They all sell them including Harbour Breeze themselves..
  1. The Home Depot® - homedepot.ca‎
    Adwww.homedepot.ca/fans This ad is based on your:
    • current search terms
    • recent searches on Google
    Visit Google's Why This Ad page to learn more or opt out.
    Discover Canada's Online Source for Ceiling Fans & Lights. Shop Today!
.spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
Search Results
    Shop Ceiling Fan Parts & Accessories at Lowes.com
    www.lowes.com/Lighting-Ceiling-Fans/Ceiling-Fan-Parts.../_/N.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass ... Missing: lighthouse
    Shop Ceiling Fan Light Kits at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Light.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted .... Harbor Breeze 4-Light Antique Brass Ceiling Fan Light Kit with Shade Not Included Glass or ... Missing: lighthouse
    Shop Ceiling Fan Globes & Shades at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Globes-Shade... Shop a variety of quality Ceiling Fan Globes & Shades and Ceiling Fan Globes & Shades that are available for ... Sea Gull Lighting (2) ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass Shade. Missing: lighthouse
    Amazon.com: Harbor Breeze - Ceiling Fan Light Kits ...
    www.amazon.com > ... > Ceiling Fan Light Kits Lighting & Ceiling Fans All Home Improvement Best Sellers Lamps & Shades Ceiling Lights ... Harbor Breeze Springfield II 52-in Antique Bronze Downrod or Flush Mount Ceiling ... Harbor Breeze 52-in Springfield Brushed Nickel Ceiling Fan with Light Kit ... Harbor Breeze Outdoor/indoor Lighthouse Kit Weathered Copper.
    harbor breeze light kit parts - Harbor Breeze Shop
    harborbreezeshop.com/tag/harbor-breeze-light-kit-parts/ Jul 25, 2012 - You can also have the option of choosing different lamp shades, or if in case ... The 52? Harbor Breeze Avian ceiling fan with a built-in light kit from .... has a style inspired by the clean, strong lines of a welcoming lighthouse.
Feb 01, 2016 | Dryers
My harbor breeze ceiling fan transmitter is staying lit , and doesn't control the fan or light correctly
Transmitter or receiver OR both need replaced. That's a low-end store brand for LOWES only. Remember, you get what you pay for.
Sep 01, 2014 | Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Replace harbor breeze light switch
Go to Lowes, where you bought this useless fan, and buy the two wire switch and replace the bad one.
Sep 17, 2013 | Westwind Classic Hugger Polished Brass 52"...
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
Dec 31, 2009 | Dryers
Hampton Bay 24002 Ceiling Fan Logo
5,655 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
