Watching tv and suddenly shut off, turn the power button makes some noise screen remains black. Is this the bulb that went out?
  • 4 more comments
  • bryan367 Nov 09, 2010
    mitsubishi 1994 model CS-31203
    unplugged for 1 minute turned back on it will click two - three times and thats all it does, no light or anything on the sreen just clicking sounds.
    YIKES! not since High school (20 years ago), I do not own a multimeter and yes I can solder. my son was playing x-box does it have anything to do with that?
    seeing that its 16 years old is it worth saving? what kind of cost is this to fix? is the bulb next?
    the cost of 100-150$ is that me doing or taking it someplace?
    good to know! thank you very much for all the help!
  • 4,889 Answers
Can I have the make and model of your tv so that we can start the diagnosis?
Posted on Nov 09, 2010
  • 4 more comments
  • eagle338
    eagle338 Nov 09, 2010
    Its not the bulb. Its shutting off due to an over-voltage fault. Before we assume that anything is knocked out, turn off the set and unplug it from the power supply. This will ensure that any protection circuitry activated are reset. Hold for one minute and turn it back on. If problem persists, let me know.
    Sai.
  • eagle338
    Then its definitely an OVP fault. Apparently one of the components on the protection circuitry , that control the amount of voltage flowing into a particualr circuit have failed. We are gonna have to do some component level troubleshooting to fix this which begs the question- Have you worked on electronics circuits before? Do you know how to use a multimeter? Do you know how to solder?
  • eagle338
    No it does not have anything to do with that. It is usually caused by a power surge or if the component somehow fails by itself(wear and tear kid of thing).
  • eagle338
    Its gonna cost you around 100-150$. As for replacing it with a new set, its a rather tough question, as the LCDs, plasmas and projection tvs breakdown in about 3-4 years max. So it might be worth fixing it. The lamp(CRT) you are referring to last long. Really long. I have seen these babies work for 20-25 years!
  • eagle338
    Well taking it to some place of course. A bulk of that is service charge. The components that have to be replaced are gonna cost you around 10-15$ max. So 150$ to get this baby up and running
  • eagle338
    You are welcome. Thank you for using Fixya!
I need to know how to chage the screen lens ?
I was watching my 56 inch RCA tv when it made a sound like a broken bulb and went out. Now when I turn on the tv it only makes a little noise and the screen is black. I have had this tv for approximately ten years, bought it brand new.
Mar 11, 2010 | Toshiba 51H83 51" Rear Projection...
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
Dec 30, 2008 | Microsoft Windows XP Professional
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Black screen
Sound like you have problem in two major.
1. Check the if there any short component in the primary and secondery side of the power supply.
2. If the component are ok in the power supply.Check in the deflection area.
Good luck.
Dec 06, 2007 | JVC AV-48WP30 48" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
Top Televison & Video Experts
