Question about Sunbeam 5890 ExpressBake Bread Maker
Where can i buy a replacement pan? - Sunbeam 5890 ExpressBake Bread Maker
    Genius:
  • Sunbeam Master
  • 1,280 Answers
It looks like these folks have your pan....just scroll down until you see your model # ......5890 and click on it...actually I think this link is already on your pan!
http://www.vendio.com/stores/breadmakerguru/category/5890/catId=3449353
please rate/rank/testimony if this gives you what you were looking for....Thanks!
Posted on Nov 09, 2010
Replace oil pump sending unit
Drop the oil pan it a few bolts pull it out and replace buy the part first so u know what ur looking for n buy a new oil pan gasket good luck hope it helps u
Feb 02, 2014 | 2002 GMC Sierra 1500
The 5891 has an O-ring seal inside that helps secure the pan when inserted. This seal came out and as a result the pan wobbled back and forth during the kneeding cycle and, I believe, caused the spindle...
Hi, I have looked to expecting to find one but ran into the same thing you did. I didn't try Sunbeam Oster though, maybe they would have one. I buy and sell and repair bread machines sort of as a hobby. If you ebay, I have a cuisinart and your model of sunbeam up for sale this week. If you ebay and are interested in just getting a replacement machine the one I have advertised has never been cooked in so the pan is new. If you ebay just type this Item # in the ebay search bar:
260688801609
best wishes and happy breadmaking!
Nov 08, 2010 | Sunbeam 5891 Bread Maker
Cant get oil plug loose
FIRST: oil the plug (I know it sounds redundant)
1. breaker bar instead of ratchet wrench (buy one if you dont have one)
2. extension bar on breaker bar handle
If Getting desperate:
1. buy a new oil pan plug
2. use a damaged/rounded extraction socket on a breaker bar.
3. use an extension handle on the breaker bar handle
Be prepared to buy (and install)a new oil pan if the threads on the oil pan are ruined.
Installing a new oil pan is "easy" for experienced mechanics, but
replacing one can be involved for 1st-timers - and you'll usually want to buy (and install) a new oil pan gasket with the new oil pan.
That's everything from breaker bar (your minimum for stuck bolts) to replacing plug and pan (the worst-case scenario).
Sep 21, 2010 | 2006 Chevrolet Monte Carlo
I have a Zojirushi bbcc-s15, and it started to leak from the bottom pan. The felt washer on the bottom has fallen off. Where can I find or how can I replace the outer and inner parts?
All those parts are part of the sealed bearing that is stamped into the bottom of the pan. Unfortunately they can't be replaced and you will need a new bread pan. Sorry Hank
Mar 10, 2010 | Zojirushi BB-HAC10 Bread Maker
Oil pan leak
buy a tube of sealer called Right Stuff
1. Remove the flexible exhaust pipe
2. Disconnect the downstream catalyst monitor sendor (OXYGEN SENSOR)
3. Drain engine oil
4. Remove the 15 bolts and the oil pan
5. Clean pan & surface area.
6. Apply sealer 10mm (0.40 inch) diameter of sealer
7. Position oil pan and hand-tighten the oil pan bolts
8. Start with front of oil pan tighten each bolts going around oil pan till all are tighten up.
9. Install exhaust flexible exhaust pipe
10. Connect OXYGEN SENSOR connector
11. Lower the vehicle.
12. Fill oil 5w20 (Spec)
Feb 10, 2010 | 2001 Ford Escape
How hard is it to replace the oil pan in an '04 Acura TL?
As to how hard it is to replace that depends. If you can remove the oil pan without removing any other parts then it is a simple repair. But if you must remove other parts in order to remove the pan it can be more difficult. Crawl under the car and see what must be removed in order to get the pan off. If you can buy a new oil pan for $95 then by all means buy it and replace it yourself or hire a trusted mechanic to do it for you. I can assure you it will not cost $300. At least find out what it will cost if done by someone other than the dealer. Honda's are reliable cars but their oil pan drain plugs are not. The problem is Honda uses an aluminum drain plug washer and this requires you to torque it to 29 ft/lbs in order for it to seal properly. Over time this will cause the pan threads, which are weak, to distort and eventually end up stripping out. The solution when you install your new oil pan is to not use an aluminum washer and instead use a fiber washer. If you pay someone else to change your oil, be sure and tell them to leave the fiber washer in place and not to install an aluminum washer. You then torque it to 15 ft/lbs and never have a leak or stripped threads. Another alternative is to just replace the drain plug with an inexpensive rubber drain plug you can purchase at any auto parts store. It will seal the drain and you just throw it away and install a new one at every oil change.
Dec 08, 2009 | 2004 Acura TL
The car is leaking oil and the mechanic said it was because there is a whole in the oil pan and it will cost 1800 to fix. can i buy another oil pan and put it on myself?
OIL PAN
REMOVAL
Drain engine oil.
Remove front engine mount bracket.
Remove power-train bending strut.
Remove structural collar from oil pan to trans-axle Structural Collar - Removal and Installation
Remove trans-axle lower dust cover.
If equipped with air conditioning, remove oil filter and adapter.
Remove oil pan.
Clean oil pan and all gasket surfaces.
INSTALLATION
Apply Mopar® Silicone Rubber Adhesive Sealant or equivalent at the oil pump to engine block parting line Oil Pan Sealing
Install a new oil pan gasket to pan.
Install pan and tighten screws to 12 N·m (105 in. lbs.)
Install oil filter and adapter.
Install trans-axle lower dust cover.
Install power-train bending strut.
Install front engine mount and bracket
CAUTION: The torque procedure for the structural collar must be followed, as damage to oil pan or collar could occur.
Install the structural collar Structural Collar - Removal and Installation using the following 3 step torque sequence:
Step 1: Install the collar to oil pan bolts and tighten to 3 N·m (30 in. lbs.)
Step 2: Install collar to trans-axle bolts and tighten to 108 N·m (80 ft. lbs.)
Step 3: Final torque the collar to oil pan bolts to 54 N·m (40 ft. lbs.)
Fill engine crankcase with proper oil to correct level.
Auto Zone carries the Oil pan you need for around $75.00 and they will have the step by step instructions for you to replace the oil pan. will take just over 2 hours for the average person. Good luck and keep me posted.
Nov 30, 2009 | 2002 Dodge Neon
I managed to scratch the loaf pan and am looking to buy a replacement for my Tr520 Breadman breadmaker. Not proving to be very easy. Help!
Check out ebay. They seem to be expensive....For some reason I think the manufacturers don't sell the bread pans separately so you have to buy a whole new machine.
http://cgi.ebay.com/NEW-Breadmaker-Bread-Machine-Pan-Breadpan-TR875-TR520_W0QQitemZ380140130482QQcmdZViewItem
Hank
Aug 31, 2009 | Breadman TR520 Bread Maker
Gasket needs replacing
then you need to replace the gaskets drain oil from oil pan take all bolts out and drop the pan as far as valve pan covers buy rubber gaskets not cork they are a lot more pliable and less prone to leak
May 22, 2009 | 1994 Ford Aspire
2001 Concorde 3.2 L Oil Pan Removal
if you have your old drain plug take it to a auto part store get a self tapping drain plug! save big$$$$$ I have installed piles of these they last for ever $5-$20- for one. cheers
Dec 24, 2008 | 2001 Chrysler Concorde
Sunbeam 5890 ExpressBake Bread Maker Logo
90 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
