Question about Black & Decker Kitchen Appliances - Others
The part that the kneading paddle connects to in the machine is not working. Will not turn the kneading paddle
  • Daryl Nash
    Daryl Nash Nov 09, 2010
    if you remove the pan and look underneath can you turn the little "ears" with your hand, and if yes does that turn the spindle the paddle sits on?
  • 433 Answers
Hi, The sealed bearing that the paddle shaft fits through is frozen and has failed. You could try filling the pan 1/2 way with hot water for a few times to see if it turns but otherwise a new bread pan is needed. Hank
Posted on Nov 10, 2010
Can't get knead bar on West Bend automatic bread maker
Was the bar ever installed on your bread maker? Is this a replacement knead bar (paddle)?
Jan 01, 2013 | West Bend Bread Maker Machine Knead Bar...
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
The bread machine will not knead m I have made sure it is connected right and even started over with a new batch, it makes the nosie like it is trying to work but will not knead.
Hi, A few things may cause this problem. Make sure the bread pan is inserted correctly in the machine. If ok, then take the bread pan out of the machine and see if you can turn the paddle by hand. It should turn nice and smooth, If it sticks or does not move then the sealed bearing that the paddle spins on has failed. If that's okay then keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning smoothly. If no then the belt is loose, broken, or has fallen off the pulley.. Good luck Hank
Jun 04, 2010 | West Bend 41077 Just For Dinner¿...
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
The knead paddle on my bread machine is stuck, what can I do to remove it. I have tried putting soapy warm water in the bread pan and leaving it sit for 30 minutes, but it did not work. I recieved this...
just go to youtube and type in "how to remove a stuck bread machine paddle or kneading blade" you will see my video of how to remove a severely stuck bread machine paddle.
Apr 20, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Kitchen Appliances - Others Logo
139 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
