Question about Air Hogs Toys
Air hog wall and ceiling rc car wont climb up walls anymore. New batteries did not fix it. 2 days old
I would check a few things:
1. Do you hav dust and debris on your tires/suction? make ure it's totally clean.
2. Are your walls completely smooth? itwont drive on uneven or rough surfaces
3. make sure that you are charging it correctly andthoroughly (refer to instructi sheets for proper method)
4. Mke sure you switch the mode from "ground" to "wall" on the front of the car.
Hope that helps! If not, contact Air Hogs Customer Care - airhogs.com
Posted on Nov 09, 2010
Dip switch settings rthl2310
Check for cold air inside the wall behind the thermostat, a cold wall, and area that is getting hot or cold air blowing on the thermostat. Last, the heater may not be compatible with some digital thermostats. Honeywell Customer Care toll-free at 1-800-468-1502.
Aug 29, 2014 | Honeywell Programmable Thermostat Heater
Air hogs charger blinks red then turns off
Make sure you have the switches set properly.
Dec 28, 2012 | Air Hogs Toys
Hyperactive air hogs rc car keeps going doesnt stop how do i fix it?
I had that problem to but I fixed it. I'm not sure if it would work because I don't have a airhogs hyper active I have a air hogs hyper active 5. So to fix it there should be a dial next to the tire on the remote so you have to put thatdial thing in the middle
Aug 17, 2012 | Toys
The fan/light will not come on with the remote. Yes remote batteries are new. The light fixture have power. I think the model # is JY97381. receiver # is UC7067RC. Unsure how to fix this problem. Can u...
Hello Susan,
If the indicator light on your hand-held transmitter lights up when you press the buttons, it normally means it's working. The problem is probably with the UC7067 receiver in the fan. One sure way to destroy the UC7067 is to have the power going to it controlled by a dimmer switch on the wall. If this is the case, replace the dimmer switch with a standard on/off toggle or an in-wall transmitter. You can find both a replacement UC7067 receiver and either another hand-held transmitter RC-210 or an in wall transmitter WC-210 at this address: http://www.fanmanlighting.com/shop/pc/viewCategories.asp?idCategory=57
Hope this helps!
Dec 11, 2010 | Minka Aire Ceiling Fan
Wont climb wall
Thank you for posting your question here on Fixya.com.
Several possibilities to consider...
How old is the filter bag and is it clean?
Older bags or bags not thoroughly cleaned can resist water passing thru them to the point there is not enough downward pressure to allow the unit to 'bite' the pool surface and climb.
How worn are the brushes and tracks?
Worn brushes and tracks will slip once worn enough. Replacing them could fix the problem.
Is it trying to climb or does the unit start up the wall and immediately reverse?
If your motor has been replaced new style motors spend far less time climbing assuming most debris will instead be found on the pool floor. If it has not been recently replaced the program within the motor may be failing.
What is the condition of the pool?
Low water temperatures and/or algae can cause the unit to slip in place and as a result it will not climb. Eventually it will scrub enough to gain traction and will slowly progress up the wall. For temperatures below 70 degrees the unit will find in more and more difficult to climb the lower the temperature.
What material is the pool surface?
Some linered pools and fiberglass pools require climbing rings in the brushes. Do you have those? If so, what condition are they in? Worn rings or missing rings will prevent climbing those and other smooth pool finishes.
For more troubleshooting tips try our site at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. You can also check the manufacturer's site at www.maytronicsus.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Nov 23, 2010 | Dolphin Maytronics Advantage
Low pressure of 5 on our pool pump. Replaced sand, replaced filter O ring, no air leaks (no bubbles, no air in pump), and no clog in the filter line (bought a device to clear out any potential clogs, and...
Sounds like your impeller is clogged, you might be able to remove the pump basket and feel inside the impeller to see it it's impacted with debris. You may have to pull apart the pump to clean it thoroughly.
Jul 10, 2010 | Pool & Spa
Heli spins counter clockwise
See solution 2 for post "How do i fly my spin master air hog rc helicopter?"
Jan 03, 2010 | Spinmaster Air Hogs RC Reflex Micro...
I have a brand new air hog jet set and I have charged it 5 times and only flew it 5 times. Now it only runs for about 15 seconds then dies. It shows to be fully charged, but it still only runs about 15 sec...
does the Air Hog Jet set for beginners AH-56 white have weights on the wings and on left center? their appears to be intents where possible weights would go but their not there, is this why it won't fly since purchase, could this plane have a deffect?
Dec 08, 2009 | Air Hogs Toys
Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054
I had a similar issue with my fans. The fix I came up with was my remote was faulty. An easy fix because I had 2 fans with the same remote.
Jun 29, 2008 | Dryers
Toys Logo
141 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
magna buff
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
