Question about Dryers
Whirlpool Electric Dryer Model# LER4634EQ2. Serial MH3840566. Timer is cutting off within 5 minutes or under.
  • Dryers Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. I am assuming that your in a regular dry cycle and the timer is adancing rapidly. This is usually caused by a bad cycle thermostat. The thermostat is located on the rear face of the blower housing above be near the 4 inch circular ducting that goes to the rear of the unit.
(Item 24) This link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246724&diagram_id=44786#d44786
Clicking on item 24 will bring up a detailed view.
You can check this with an Ohm meter and a match but you need to be quick. Cold it should read continuity. Heat it until it clicks then it should read open.
I am a bit perplexed by looking at the parts break down because most cycle thermostats have 3 terminals. One being common, one when cold would power the heating element and one when hot would provide power to the timer motor. Your timer is advancing because there is always power to the timer motor. There should only be power to the timer motor when the cycle thermostt is HOT. I.e above 155 deg F. It will continue providing power to the timer motor until the temp drops to 130 deg F at which time power is re-routed back to the heating element.
Inside the dryer usually glued to the side of the cabinet is a 4 x 5 envelope with a tech sheet inside that will have the details of your timers operation and checks.
Here is the 3 terminal thermostat details
Pink / White wires - 503979 Thermostat cycling (Gas and Electric Models)
S.P.D.T. - 3 terminals Measure resistance of the following terminals:
Terminals 1 - 3 .............................. Open at 153° ± 5° F
Heat thermostat with a small flame until a distinct click is heard.
Terminals 1 - 2 .............................. Close at 138° ± 5° F
Continuity < 1 W
The thermostat your looking for should have 3 terminals. DO NOT heat the thermal cut off with a match. It is a one time failure / must replace at that point item.
Thanks for choosing FixYa,
Kelly
Posted on Nov 09, 2010
I have this model dryer ler4634eq2, all you can here when you try to start it is the timer, I have checked and jumped both the thermal switch and the door switch, I have also tested my start switch for...
Check to make sure the belt is not broken. This may have the belt switch located behind the motor and if belt breaks this will also have same results since every thing else has been checked. Hope this helps.
Mar 02, 2010 | Whirlpool LER4634J Electric Dryer
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Whirlpool Dryer LER4634EQ2
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
Mar 07, 2009 | Whirlpool LER4634J Electric Dryer
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
