Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio washer stopped working on the drain and spin cycle. Tried turning the machine on and off, different settings, etc. Still doesn't work. Water is in the tank.
    Habit-Forming:
    New Friend:
  • 77 Answers
The out let valve not responding
Posted on Mar 04, 2015
gwshaw71
  • 83 Answers
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Posted on Nov 30, 2007
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
Yes a warranty is good on these machines and the first visit will justify the cost. Ld is long drain and can be caused by two problems. One is junk in the pump and the second is a drain hose inserted past the water level in your pipes. Simply stated when the machine drains you should here the water hitting the drain. If you pull the hose out and there is a water line on the hose it is inserted at least that much too far. Another detail is to make sure you use he soap as the old stuff foams too much for these machines.
Posted on Sep 20, 2008
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Posted on Sep 30, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My whirlpool cabrio washer has started shutting off half way through the wash cycle...won't drain and spin...could the motor be overheating or is there something else I can check?
Most likely the cycle timer needs to be replaced. it is basically a clockwork device that that has cogs attached to a spindle. if you check the schematics for your product you will find the part no. etc. any servicing of course needs to be done wit the power disconected
Jan 20, 2013 | Whirlpool WTW6400SW Cabrio Washer
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
384 people viewed this question
Dan Webster
Dan Webster
Sal De
