Question about Hitachi 55HDS69 55 in. Plasma Television
Hitachi 42in, blackline down the middle
I've got a solid black line down the middle of the screen, it comes and goes but it mostly stays on now. Any suggestions??
  • 1,139 Answers
This might be due to the screen not receiving drive signal from the screen driver board; dry solder connections, broken bus lines, and or defective screen could be the problem. I would suggest taking the set to a qualified TV repair shop and having them diagnose and repair this issue, due to the damage that might be caused by the removal of the broads to get at that part of the set.
Posted on Jul 14, 2008
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
Black box in middle of screen
go into the menu and turn your closed captions off or if there is a cc button on your remote you can turn it off that way.
Sep 08, 2009 | Hitachi 57F500 57" Rear Projection...
Black vertical line on screen
this tv has 3 drive boards at the bottom of the tv, inside the back, hard to get to them, there is one in the middle , and one on each side, they usually cost arount 100 dollars, the drive board below where the line is, has probabily gone bad, but about 20 percent of the time, you can undo the ribbon connector where the line is, and reconnect it, and sometimes it will fix it,
Jan 09, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line on middle of screen
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.)
Take your TV back if it is under warrantee.
Dec 11, 2008 | Hitachi SSH2442 Television
Black Line Down Center of Screen
Dry solder joints on the pins of the vertical integrated circuit may have caused this problem Tap each I/C lightly with a plastic screwdriver handle to find the intermittent one. It is the one with a heat sink attached.
Aug 10, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black lines vertically down the middle of screen. Comes and goes
it should be a problem in the converter board so its better to replace tha boars if there is a warranty other wise u can buy it .if u still wait that problem will become more crucial
May 20, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line down the center of screen
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
Black mini screen in the middle of screen...
Go to the closed caption menue and turn off "text"... That's a text box and in most areas there is no feed so the black box is all you'll get...
Dec 09, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 55HDS69 55 in. Plasma Television Logo
137 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
