Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I've plugged it into the power socket, and put in the usb, yet no light turns on, indicating that it has not been recognized by the computer. what do i do?
    Scholar:
  • 79 Answers
When the drive's dc adapter is plugged in, are you able to feed the hard drive start-up and begin to spin? Because if not, you either have a faulty dc adapter (unlikely,) or the power inverter board on the external hard drive case has failed. If there proves to be no power being delivered to the drive, even after trying a different adapter, then I would believe that the issue is in the case. Most likely, none of your information is lost, as inside the casing is a standard sata hard drive, that, with the proper tools can be removed and connected to a computer.
Let me know what you find and I'll be able to help you out better.
-David.
Posted on Nov 09, 2010
Testimonial: "very helpful, and will be even more if you help me fix this!!"
  • ruthushan_12 Nov 09, 2010
    ok, well, its it is not starting up, the external indicator light is not on.
    Problem Solver:
  • 16 Answers
Most, if not all computers detect external hard drives before windows starts to load. If you see no evidence of drive data light activity i would go into the bios to check you have the right usb settings. You will also see all the hard drives that are connected to the computer. If yours is missing, and nothing you do to the usb settings will bring it into play, then your motherboard cannot take usb hard drives. Of the 23 computers i have built 4 had a bios that would not work with an external hard drive. Yours may be one of those that just don't work with them
Posted on Nov 29, 2010
My magic jack plus will not work and I am wondering if the electrical connector is bad.
Go to the magic jack website and update your adapter. Also try different USB ports and reboot your computer with magic jack connected. If the computer does not recognize the adapter, try disconnectin and reconnecting into different ports. There is a update option on magic jack website and tech support as well.
Nov 04, 2014 | magicJack PLUS VOIP Phone Adapter
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Cannot get my Lexmark Z2420 printer working--it has the wi-fi capability, but trying to connect it via USB. Should be plug-and-play but windows makes a sound like it recognizes it, but nothing comes up as...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/9xPHL4. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 26, 2011 | Lexmark Z2420 Printer
Motorola VE 440 computer does not recognize when connected w/USB
you might want to try it with a computer running Windows Vista - older operating systems will generally tell you that something is plugged into the USB port but will not allow you to access it as it does not recognize new software.
Mar 19, 2010 | Cell Phones
Green light blinking, won't turn off and can't print anything
unplug your usb or any cord that links to your printer...
then press and hold the power button of your printer (it should force your printer to shutdown)
then plug-in your usb cord (connector/cable) back to your computer then turn in you printer again... wait for your computer to recognize it
(note the green light blinking is an indication that the printer is busy) therefore you should wait for it to be recognize (note: a sound maybe heard once your computer recognize it, some may appear as pop-up)
it should be ok now make sure you still have ink in your cartridge
Jul 07, 2009 | Lexmark X2470 All-In-One InkJet Printer
Using Windows Vista Suddenly can't see WD MyBook 500G
I had a problem with MY Book and I found out that if you plug the drive into a power strip it doesn't receive enough power, so it doesn't show up on Vista, but if you turn everything off and then plug the My Book directly into a wall socket, Vista will see it and put an icon in the My Computer area.
Jun 04, 2009 | Western Digital 500GB My Book World...
Usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Dec 29, 2008 | Sony VAIO VGN-SZ110/B Notebook
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
let me know if that helped !!!
Dec 01, 2007 | Konica Revio KD-400Z Digital Camera
Zonet ZUN2200 Issues
I have the same problem when connecting my ipod and usb hard drive. I think the card is just a piece of crap. I've also tried a different card before but had no luck either. I guess its time to get a new laptop.
Aug 24, 2006 | Zonet 2-Port USB2 Cardbus (PCMCIA Type II)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
1,150 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
