Question about Whirlpool Duet GHW9150P Front Load Washer
Placed the washer on heavy duty and 3/4 of the way it stopped and it has the light of CONTROL LOCKED on and there is no more movement What do I need to do???
    President:
  • 1,554 Answers
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fails to unlock it.
Posted on Nov 09, 2010
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
Kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
