Question about Whirlpool LSN1000LW Top Load Washer
The washer filled up with water but wont turn on
    President:
  • 1,554 Answers
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch. The machine, therefore, will not turn on when the lid switch is not working. Manually activate the lid switch and if still doesn't work, bypass the lid switch. Disconnect power then jump a wire between the outer terminals of the disconnected connector from the cabinet top then reconnect power. Replace the lid switch to address the problem if the machine works with the lid switch bypassed.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switchthe washer filled up with water but wont turn on - jahn27_10.jpgector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdrthe washer filled up with water but wont turn on - jahn27_11.jpg turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tithe washer filled up with water but wont turn on - jahn27_12.jpg the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
the washer filled up with water but wont turn on - jahn27_13.jpg>Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Nov 09, 2010
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
My GE washer wont stop filling in any cycle. Even if you pull out the plug. Leaks everywhere. I blew into water level switch hose and it clicks. Model number WBXR1060T. Thank you
If water continues to fill and you have unplugged the washer from the wall then your fill valve is stuck open and needs to be replaced. Turning off the water at the wall faucet should stop the water. The fill valve is what the hoses are attached to at the washer.
Feb 02, 2010 | Washing Machines
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Jun 29, 2009 | Washing Machines
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Wont fill with water
I probably has a bad fill valve or a clogged screen suggest check to see if the fill valve is engaging and if there is water getter past the valve.
Jan 20, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LSN1000LW Top Load Washer Logo
95 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
