The cassettee player, which has auto reverse, would not player, it keeps attempting to switch to play the other side. If you manually remove the tape and turn the playing head it will then function fine until the next time you attempt to use it. Can this be repaired?
    Guru:
  • 2,178 Answers
Yes - it needs to be take apart to replace a damaged belt or idler wheel.
Posted on Nov 09, 2010
Shifting hard
auto trans or manual? If auto, the difficulty could be from a failing brake light switch. That switch also controls the shift mechanism. You have to get on the floor board on the drivers side, while it is in park of course. Depress the brake pedal with your hand, you will see the switch depress. You want to remove that switch, take it to your auto store, get a new one, reverse the removal process
Jul 07, 2014 | 2004 Chevrolet Aveo
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Casstte Player- '94 ford
I think you are saying you are using a cassette adapter to play the external iPod/PSP etc. and I presume the cassette plays regular tapes OK. The auto-reverse cassette player thinks the 'tape' is over, so reverses then ejects. You can try putting in a regular tape, change sides then eject. Try the adapter again. Hopefully the adapter will work in 'one' direction.
Apr 13, 2009 | Car Audio & Video
I have XM radio hooked to cassette player adapter in my car. The new adapter keeps sounding like it is rewinding. XM plays for 30 seconds and then ''rewinds'' again, over and over.
Unfortunately your tape play has the auto reverse feature. It is detecting that the tape is not turning via a reel counter. Sensing no movement ( as you have an audio adaptor inserted rather than a real tape) it is trying to switch to the other side of the tape.
Not very much you can do.
You could purchase an FM modulator and basically re-transmit the Xm over an un-used frequency on the FM band to slve your problem
Mar 12, 2009 | RCA Audio Players & Recorders
Tape player keeps switching sides
The adapter is tripping your radio's auto revere. The radio thinks it's at the end of the tape so it switches sides. Tape adapters especially the cheaper ones are made a couple 100,000 at a time an sometimes the machine that makes them is off so it makes bad adapters. If you look at the face of the adapter you will see a silver head in the center just to the left an the right of the center hole you'll see two smaller holes one on each side. look inside these holes an make sure there's nothing in them no padding or plastic tabs. If there is anything in these holes remove it. This is whats tripping the auto reverse .These hole should be about a 1/4" deep . next with a small razor blade shave all four sides about the same as the thickness of the blade this should remove any burrs or misshapen plastic.
Feb 08, 2009 | JVC KS-FX250 Cassette Player
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
 Grubhead
Grubhead
