Question about Konica Minolta magicolor 2400 Laser Printer
NOT GRIPPING PAPER
I WAS TOLD THAT MY PRINTER WON'T PRINT DUE TO THE ROLLERS NOT GRIPPING THE PAPER. IS THERE A SOLUTION?
DEBBIE
    Champion:
  • 214 Answers
Hey,
first clean paper take up roller.
Posted on Jun 19, 2008
Hp laserjet m3035 mfp does not take up the paper squeaks and reports paper jam - no papaer is jammed
The most common cause of this type of Phantom paper jam is worn pickup rollers and separation pads in the paper trays. When these rollers get worn the gripping surface can not grab the paper correctly so no paper is fed into the printer and the printer gives the paper jam error. The rollers are very easy to replace, it takes about 20 minutes total. Here is a link to more information about the roller maint kit:
www.ccl-la.com/catalog/product_info.php?products_id=172
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
I am having trouble trying to print card stock paper
110lbs?
that may be too heavy, try a few first then check if the printer will initiate printing.
Jun 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
The paper feeder rollers are slipping and the paper is not feeding properly. What can I do to fix this?
This is a good workhorse printer -- I serviced these for many years.
You can try cleaning the paper feed rollers with a rag moistened with a little white spirit. This helps remove the paper dust build-up that glazes the rollers and prevents them from gripping the paper.
Eventually, as the rollers become worn, (or, if they are already too worn) you will have to replace them.
Apr 05, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
We are printing round labels on a 170XiIII plus I have no blackmark so it?s very difficult to calibrate this label When the printjob starts it backfeeds but not far enough to print the complete label I?ve...
No, well not really, the printer requires a area that it is allowed to touch where there is no image being laid, for if it did so allow ink on that area it would go on to the feed rollers and prevent them from gripping you paper.and producing marks on the edges..
but I guess, one may be able.. to place or stick a fake lead edge of paper on your paper, so that your printer may be able to grip your paper,, and you can place your image, or even putting in a custom page size that is ,20 inch extra long incorrect....
although this may work, the printer may or probably will indicate or go into a jam at the end of print due to page length being detected incorrectly, so you couldn't do a run, may get print warnings, and rear exit edge wouldn't print... but it might get you one at a time....give it a go, I'm only trying to explain why we need that edge and the back feed..so we can get a grip :)..hope this helps cheers..
Nov 27, 2009 | Office Equipment & Supplies
In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
Paper will not feed through the printer
The rollers are becoming worn and / or a little dirty, which makes them slippery. If you can reach the rollers that grab the paper, (i don't know the accessibility of them on this printer) and clean ( while turning) them with a dampened cloth, it should help.
Mar 17, 2009 | Epson Stylus C62 InkJet Printer
Paper will not feed into the printer.
I opened up my CX4200 and cleaned the feed rollers with a Q-tip wetted with a bit of cleaner, now it feeds fine. Looked like there was some dried ink splatter on the rubber rollers, that was probably preventing it from gripping the paper properly.
Oct 18, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer will not feed paper
Mine did that too.
I found that propping the paper feed cassette up at the end away from the printer worked.
May 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
Konica Minolta magicolor 2400 Laser Printer Logo
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
