F30 comes up and the drain basket is empty - Washing Machines
  • 12,061 Answers
F30/31 - Motor Error
If this error occurs then you should try to run the programme again, but a persistent problem will need to be looked at by a professional. A F30/31 error code can indicate a fault with the carbon brushes, drive belt, motor relay or PCB. You can buy spares for your Hotpoint washing machine at many places on the 'net, simply Google for it.
Posted on Nov 09, 2010
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
Won't drain
  1. Food & debris are blocking the drainage basket (or drain screen) inside the tub, in the far back
  2. Food is clogging the drain hose - the long tube that runs under the sink
Apr 25, 2014 | GE Dishwashers
Do you have to buy picnic baskets with cutlery and crockery inside? I really just want an empty basket as I would rather use disposable stuff.
Picnic baskets come both empty and full. You choose whichever one you prefer. Here is a link to the Picnic-Basket site where they have a selection of empty baskets.
http://www.picnic-basket.com/empty-picnic-baskets.html
Feb 27, 2013 | Home
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Both of the Pegasus baskets in my sink have come apart. I put them back together and they come apart again. I would like to purchase new baskets, but can only find the entire drain assembly, which I do...
I know what you mean I had similar problems with my sink strainers, unfortunately is you want to get a good working basket you have to buy the whole drain assembly. You can get some cheap ones at a home store but they will only break again and probably won't match up. What I recommend is swapping out your drains with a drain brand that won't break again like Kohler, Moen, or Elkay. All you need to install a new drain is the new drains, a drain nut removal tool and some plumbers putty. Take the old drain out clean around the whole and install the new one with a ring of plumbers putty around the hole.
Jul 09, 2010 | Pegasus Technologies Pegasus Kitchen Sink...
Water seems to be coming from underneath
Check that your drain hose is fully inserted into the wall/floor drain. then run an empty load with just water and watch it during the drain cycle to see if either the drain is backing up or if it's not fully connected at the back of the washer. if the drain is backing up you can try a drain sn ake available at most hardware stores and that will most likely clear it. If it's leaking at the connection at the back of the washer try to push it in fully or replace the hose altogether. It's not the water inlets because they always have pressure on them and would leak constantly. or you could have a cracked basket in which case you will be better to buy a new machine. cracked baskets don't happen very often though. And once in a blue moon it could be an off balance issue where its actually splashing out. Either way you need to spend some quality time with your washer and see why it's crying =]
May 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Waste ink near full - how do I empty it?
Hi
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 23, 2010 | Canon MultiPASS F60 All-In-One InkJet...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
My washer dryer won't drain, is there a drain dial setting? there is a small amount of water that won't drain away. it means the door lock won't release
the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump
Apr 21, 2009 | Washing Machines
My direct drive washer spins slow
Always rule out first: Unsorted, too big or off balance load, too high or restricted drain, oversudsing or water not draining completely out before going into spin. Otherwise the brake could be not releasing fully or the clutch lining is worn. Pull the basket and transmission and check the basket drive.
Nov 11, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
