Question about Keurig B60 Coffee Maker
My Keurig turns on, but stops warming the water before it is ready to brew. The light turns off and the status stays at Not Ready. I've found that if I unplug the unit, turn it back on, the pot then warms again for a while. If I repeat this enough times, eventually the status changes to Ready To Brew. I can brew a cup, but it doesn't seem to be as hot as before, and of course, the flavor is weak.
  • vicstclair Nov 09, 2010
    thanks but this is just a description of the problem. What is the fix?
  • 320 Answers
There is a problem with the thermal sensor of your coffee maker. The sensor is no longer accurate in sensing the right temperature.
Posted on Nov 09, 2010
  • Amado Petallana Nov 09, 2010
    Dismantle the bottom panel of the coffee maker and look for the thermal sensor which is usually attached to a steel component which is connected to the heater . Check if there is a corrosion on its surface try to clean it. If it does not fix the problem, replace it.
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
My Keurig says not ready, water won't stop coming out. when it reads brewing, it stops.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jul 23, 2011 | Keurig B100 Coffee Maker
Keurig B66 coffee maker randomly stays on and brews.
I have called Keurig and gotten replacements for units... however... all keurigs will heat water... then stop... after a while, the water will get cool, and the unit will cycle on.
when you say shuts itself off, the whole unit does Dark?
If the whole unit goes dark, then you may have a bad overtemp sensor... most if not all appliances will have this featurew to shutdown everything if the sensors detect a higher then normal temperature.
If that's happening... call Keurig and tell them this,,, they should honor the warranty and ask you to send them you K-cup holder as proof of ownership... then you will get a replacement.
you now have a unit for parts or to sell on ebay for parts...
I can allways use the parts... :)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 17, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
My Keurig B66 will no longer pump water up to brew, I have had this less than 6 mos, what should I do?
it seems that it does not pump water in, after switching it to ON, it stays running for a few minutes then shuts OFF without even showing "READY TO BREW"..
Jan 02, 2010 | Keurig B100 Coffee Maker
Keurig B60 Coffee Maker Logo
142 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
