Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
How can I find a "convergence circuit" for my 8 year old 60 in Phillips projection TV? Could I install it myself or would I need to hire an expert to do the work?
  • Philips Master
  • 8,457 Answers
There are no a whole DLP tv model Philip convergence board out there to buy.U only can buy a convergence kit,came in parts like 2 STK convergence ICS and some or all of it resistors parts for sale.Hire a shop to fix ur DLP tv convergence board.They'll charge u like $300-350 for parts and labors.
Posted on Nov 09, 2010
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
Poor convergence on my 60"
It is very possible that the IC's were not installed correctly. Check and make sure you do not have any solder bridges on your pins, or that the solder pads did not pull up from the board. If all that looks good, check your resisters that are in circuit. It is possible that 1 or more was already week and popped when the new STK's were installed. Also as far fetched as it could be, you might have gotten defective parts though not likely. I hope this helped and good luck to you.
Aug 10, 2011 | Philips Magnavox 51MP392H Rear Projection...
We have 2 Nos Philips Rear Projection TV Sets procured in year 2004. I would like to confirm the effective useful life of these tvs as I am facing problems like convergence. Is there any aging effect on...
These tv's have an expected life of 8 years at normal usage so your tv's are starting to show signs of old age.
Yes, the failure of the power circuits in the convergence board are a common occurrence in tv's of that age. So common that other companies have started to put together refurbishment/repair kits for them. This is the one for this tv - Philips 60PP9363
http://www.tvrepairkits.com/xcart/product.php?productid=23618
Aug 04, 2011 | Philips 60PP9363 60" Rear Projection...
My phillips 60 in projection tv is showing to
The two convergence ICs and 12 feed resistors are the most likliest cause. Whats your model number as you can get convergence repair kits which have parts and CD with instructions at www.tvrepairworld.com
Jul 16, 2009 | Televison & Video
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 43PP6360/79
if the hase your refering to a glowing halo its the blue coolant that needs changing. If it causing a 3D image then its the convergence ICs need changing
Mar 23, 2008 | Philips 60PP9202 60" Rear Projection...
60" Phillips Magnavox
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hourglassing
This problem is the "pincussion" setup on the convergence board. It, however can be caused by a failing power supply. If the set takes more than 60 seconds to produce the picture and up to 10 minutes to fully produce a good picture, even with the problem, power supply. Most likely if it does not do the mentioned it is the pin amp on the convergence board.
Apr 27, 2007 | RCA P52930BL 52" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
