Still about bios update
Is there commands to be typed and executed for the manual update?
thanks sir, been a great help :-)
  • 13,433 Answers
Yes, you need to check the readme that comes with the flash program, or in dos you can also find out the commands with Flashprogram.exe /? (the /? is basicly help and sould show all the commends)
http://www.wikihow.com/Update-Your-Computer's-BIOS
Posted on Jun 16, 2008
I can't connect to the windows update site. When I click on windows update it either goes to the page that says Internet Explorer cannot display the webpage, the MSN homepage or some random search page. I...
Hello Sir,
Try typing these commands and check whether you could access the update page
Commands
Re-register the Windows Update DLL with the commands below
1.)Click Start, click Run, type cmd, and then click OK.
Type the following commands. Press ENTER after each command.
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wuaueng1.dll
regsvr32 wucltui.dll
regsvr32 wups.dll
regsvr32 wups2.dll
regsvr32 wuweb.dll
Aug 12, 2010 | Toshiba Satellite M35X-S109 Notebook
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Hi sir my nokia n72 memory card not camplit formet mobile & my pc pliz help me sir
Connect your Nokia N72 to your pc and format the phone from Command prompt and you can get command prompt from start - programmes - accessories - command Prompt. You can also format your pc from Dos/command prompt. When booting the pc enter bios settings and select to boot from dos prompt, from this point you can format your pc and everything on it will be wipe out.
Thanks
May 13, 2010 | Nokia N72 Cellular Phone
CMOS BATTERY LOW CMOS SETTINGS WRONG CMOS MEMORY SIZE WRONG. I was getting that error, and then i went and brought a brand new battery, the CR 2032, the same that came after...After i booted it up, went...
  1. here are the instructions to Flash Your BIOS -
don't forget to read the information that's included and related to flashing in your motherboard's manual. Yes, dig that manual out (or if you can't find it then download it from the manufacturer's website; it's usually available) and read it!
Four of the most common flashers are: AWDFLASH, AMIFLASH, UNIFLASH and AFUDOS (only for ASUS boards). Out of these the UNIFLASH (get it here) is the universal flasher that can usually flash every BIOS; it has awesome compatibility capabilities. Keep in mind that BIOS flashing can be (and is) dangerous, because in the case of a bad flash the data ends up corrupted and your computer won't POST anymore. So I'm recommending wholeheartedly that you use the BIOS flasher that's explained in the manual and provided by the manufacturer of your board. Read the manual, do your research and when you're ready, then and only then proceed to follow the instructions.
After you get your flasher you need the latest BIOS flash file. First find out your motherboard manufacturer's name and your board's exact name and specifications. Visit your manufacturer's website and download the latest non-beta version (betas can be risky and I don't suggest you experiment if you can't fix it if a bad flash happens; we'll discuss that a bit later). These files usually have ".ROM" or ".BIN" extensions. Later on I'm going to call the "latest BIOS file" "newbios.bin."
I'm going to give you examples of how to use UNIFLASH, AWDFLASH, AMIFLASH and AFUDOS. Read them strictly as examples and do not proceed to flash your latest BIOS version before you understand what each option gives and how to use these flashers.
Flashing with UNIFLASH:
A:uniflash.exe newbios.bin
Flashing with AWDFLASH:
A:awdflash.exe newbios.bin /py /sn /cc
Flashing with AMIFLASH:
A:amiflash.exe newbios.bin /A+ /-B /-C /-D /E /-G /I /L /N /R /V
Flashing with AFUDOS:
A:afudos.exe /inewbios.bin
Even though the above commands do work it's always crucial that you read what every command does and understand them. First of all, once you're booted into MS-DOS, execute the flashers without commands and options. Just use a simple "awdflash.exe" or "amiflash.exe"-- then a help screen (which explains all of the available commands and options) will appear. Read that thoroughly before proceeding and follow the instructions.
As a side note, UNIFLASH has a UI (user interface) so it definitely helps beginners. Execute the "uniflash.exe" and the UI will appear and guide you through.
please dont forget to read precautions here
http://www.devhardware.com/c/a/Hardware-Guides/Why-and-How-to-Flash-Your-BIOS/2/
Mar 07, 2010 | Computers & Internet
Bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Nov 25, 2009 | Computers & Internet
Dell Inspiron 6400 - manually flash BIOS
If your BIOS is now corrupt you will be unable to reboot and try the BIOS flash again, not easily anyway
A lot of newer systems have special BIOS recovery procedures that can be done. You will need to consult your motherboard manual or motherboards manufacturers’ site to get these steps
Sep 03, 2009 | Dell Inspiron 6400 Notebook
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
Sir, this is jafer i forget my acer laptop bios password
To clear BIOS password!!!!
You can use following command in command prompt.
c:>debug (You will see -)
- o 70 2e (Just simply type o 70 2e)
- o 71 ff
- Q
This will work on most DOS version.
I already tested this command in win98.
o mean open the address.
This doesn't work on bios system password. Just only for bios password.
Jan 13, 2009 | Computers & Internet
I am trying to do a software update for our furuno felcom 12, sat c unit. I have the software update on a floppy disc, and have followed instructions on how to install on ms dos, but when I punch in the...
that means that file is not an executable file or not an application. try typing dir *.exe and then run the file that displays. since those files that displayed are the executable files.
Dec 22, 2008 | Computers & Internet
UPDATING BIOS FOR ASROCK M266 A MAINBOARD
In order to update your Bios, you need to have a bootable diskette.
First make sure your 1st boot sequence is Floppy Disc. Place a bootable floppy, if you don't have one just do it by using unused floppy. Right click on 31/2 Floppy (A:), choose Format, then tick the box "Create an MS-DOS Startup Disk". Once finished use this disk to boot your system. After the system completed the boot process, replace your boot disk with your upgrade disk. Type the require command to update your bios.
Good Luck
Feb 09, 2008 | Asrock M266A Motherboard
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
