Question about EPoX EP-8HMMI-A Motherboard
The computer will run awhile then shuts down. Have unplugged all other components except motherboard and hard drive.
  • EPoX Master
  • 27,725 Answers
Test your PSU power supply unit or replace it
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Nov 09, 2010
GT5670 Will Not Start...
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension lead or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
also check the keyboard and mouse batteries or ps2 or usb leads and connections if applicable
hope it helps
Jul 02, 2012 | Gateway GT5670 Desktop PC
Computer randomly shuts downs. i have checked ram/hd/psu and all are fine. It hasn't shut down on me in the bios or loding though or when playing games but it shuts down a lot when just in windows or...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 21, 2010 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Acer Aspire One, the Laptop powers on,the yellow light comes on when you hit the power button, thats about it you dont hear the hard drive running and the lcd dosent come up either,sometimes if i remove...
sounds like a power issue, may be related to the motherboard and you may need to get in touch with Acer support for it, but try these and see if it helps. turn off the system, remove the battery and adapter and remove the hard drive and memory if you can. with the components removed, hold down the power button for about 10 secs to discharge whatever power remaining. After that, connect all components, boot in BIOS and reset the default settings, and then restart the computer and observe it. Make sure to set any BIOS options again that you may have set previously.
Aug 25, 2010 | Acer Aspire One PC Notebook
When i shut down my desktop dell Optiplex gx115 and turn it on he didn't start except after a while
Have you added any new hardware/Software? Could be a bad PSU(power supply)
Make sure there is no damage around the connectors where the PSU is being hooked up on the motherboard.
Also make sure all the connectors are not loose or damage.
Make sure all components are properly seated.
how long is awhile exactly? did it start up at all or was the screen just black?
Jul 28, 2010 | Dell Optiplex GX115 System Board (49PRY)...
My Acer Aspire 5920 won't do a recovery
BSOD is caused by hardware error or driver error. Disconnect all hardware except the basic. Motherboard, monitor, memory, hard drive. Unplug the wireless, cd/dvd drive.
Start the computer and see if the the BSOD returns. If not, one by one add components until you see the BSOD.
If you continue to see this screen without any hardware attached, then you most likely have an onboard component failing. (audio/video/memory failure)
Download and run the MS DART cd and check hardware starting with memory then hard drive.
http://www.microsoft.com/windows/enterprise/products/mdop/dart.aspx
This should determine what device is failing, except video or audio.
Jan 24, 2010 | Acer Aspire 5920-6727 Notebook
Powering Issues
Unplug the computer power,
Take a close look at the motherboard, find the cmos battery..usually looks like a big shiny nickel, carefully remove
Let the computer sit for 5 minutes.
Put the new hard drive back, if it works great. If not repeat with the old drive.
Let me know what happens.
Nov 23, 2009 | MSI K9A2 Platinum Motherboard - AMD790FX,...
Computer won't shut down
i read an forum, mboar asus shutten dwon NOT avaible.
Dec 29, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
Msi7235 motherboard
Hi iggulden, I suggest you back up your personal data. Get it off the primary hard drive. While your windows is still running.
When you’re finished, find the Mfg's name of your hard drive & S/N. Go to the Mfg's web site & download their software tools for checking the hard drive/testing & setting up the drive for a fresh install of windows. Most Mfg's have software to create a bootable floppy disk & or a bootable CD. (I doubt your troubles are from the motherboard just by your description). After running the Mfg's software & a fresh install of windows your system will run much better. Give it a try before you attack your motherboard.
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Apr 03, 2008 | Intel Motherboard
My computer shuts down at random intervals, most of the time it happens when a larger program or someting with a large grafix demand is running, but their are times when it will shut off when nothing is...
Hi, Random shut down is usually the hard drive. You need to get it tested at a repair shop and ask if it could be repaired or if you will need a new hard drive. If it's not too big of a problem yet, they might be able to do a lowlevel format which will eliminate bad sectors and do a new install. However, if there's too many bad sectors, it might need to be replaced. Good Luck and let me know what happens.
May 29, 2007 | Intel Gigabyte GA-8IPE1000-G 865PE Socket...
Booting problems
As you probably have already figured out your motherboard is running into some type of error during the boot process. Try restarting the computer and pressing the del key several times after a second or two. Can you get into the BIOS now? The first thing I would do is to make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. Unplug your computer, plug it back in and reboot, paying close attention to anything that is displayed on the monitor and noting any changes from before. If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Jan 06, 2007 | MSI KM4AM-V Motherboard
EPoX EP-8HMMI-A Motherboard Logo
88 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
