Question about Electrolux Refrigerators
Need to replace water dispenser actuator how do I remover cover from door to get access. model e23cs78epso
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
Posted on Sep 23, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
aborcass
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
I need to replace the water dispenser on a Regrigerator but I can't find any way to remove the door cover or the water dispenser cover from the front. How do I get to the water dispenser?
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Nov 09, 2010 | Refrigerators
For some reason the dispenser will stop working part of the time and more recently will stick on and overflow.I pulled the cover off the inside of the door and there is ice buitl up on the insulation.
You need to thaw out the ice machine and see if it works after you thaw it out if that does not fix the problem then the control arm for the ice dispenser is bent.
Nov 22, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
How to repair the ice dispenser door on a whirlpool refrigerator
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Soap dispenser
It sounds like the soap dispenser flap is stuck or the latch is broken. Try to see if it can be manually opened to loosen it. How long do you wait before starting the dishwasher after the soap is placed in the dispenser? Check and see if the cover opens even a little during the wash cycle?
There could be a problem with the solenoid that opens the soap dispenser. I don't know of the part number for this. You'd have to call Bosch or check their website.
Mike
Jan 25, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
52 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
