Question about HP iPAQ hw6515 Pocket PC
Backup battery hi, how can i use the backup battery? it always is full and i can't to use it? thanks
  • 85 Answers
The backup battery exists to protect your data when the main battery dies. It only has enough power to keep the internal memory 'alive' so you dont lose your files, settings etc.
When the backup battery dies it should be replaced as soon as possible, as the main battery will power the internal memory only while it has charge. Should the main battery die it would be like performing a hard reset.
Posted on Jun 20, 2008
MC 9190 LongRange scanner
It looks like the backup-battery is empty
May 29, 2013 | Zebra Symbol Technologies MC909X-G Series...
Hi there, I'm wondering if I can use my "Trip Lite Office UPS500" as a surge protector only (the left 3 outlets), I don't need the battery back-up? Is it going to work properly without the...
Yes it will work just fine make sure that the outlets you are plugging into the 3 are surge protected. Thanks for using FixYa! Most battery backups and backup modules are surge protected on-board. John
Mar 19, 2011 | IBM Tripp Lite Internet Office 500...
Short backup time
Suspect battery failure/faulty cell in a batt
Remove batts and check outside unit
charge up to around 2.27V/cell then check discharge on each batt (12V car lamp is good dummy load)
faulty one will be obvious.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Jul 06, 2010 | Powerware 9120 UPS System
How do I prevent loosing data when my battery discharges
Hi. Actually, on pocket pcs there's a backup battery onboard, but in your case maybe backup battery is dead. So you can have that changed or you can charge your PDA on regular basis. Hope this helps.
Jun 28, 2009 | Toshiba e355 Pocket PC
How should i take care of my compaq presario c700 's battery?
u can take care of ur laptop by conceedaring below points like.....
1. always use a good and updated antivirus.
2. avoid with shokes means carry with care.
3. important for battery ........
full cahrge the battery and after complete discharge charge again . never keep ur battery pluged with power cable . it will increase the battery life and backup....
Mar 02, 2009 | Compaq Presario 700 470024-192 Notebook
Restriction code
1. the set has very less backup of battery. Due to poor battery backup it could not run for full day. it requres charging thrice for 24 hrs working.
2. pl provide more ring tones.
Mar 06, 2008 | Nokia 6300 Cellular Phone
The backup battery not working
Hello Paul,
Yes the battery can be replaced but this will require you to dissasemble the pda. The problem you face is a clear sign that this battery has failed. There has always been a problem with hp's battery measurement algorithm regarding that secondary backup battery. Altrough it is empty or even if you remove it, the program will still display a full bar. In order to change this battery you will need to remove the screws from the back of your unit. The casing will come off pretty easy. The back-up cell is a small coin like battery most probably wrapped in a green plastic shel. you should find a similar battery and connect the pins from the old one to the new. The battery size is not critical as long as you can make it to fit in the space inside. Try, however, not to use a very small battery because it will drain much faster then larger ones. Carefull when observing polarity.
If you need more informations please reply.
Bogdan.
Feb 08, 2008 | HP iPAQ H4150 Pocket PC
Back up battery
 recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter or insert a fully charged battery into the HP iPAQ.
Oct 07, 2007 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
335 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
