Question about Porcher 83420-00.000 L'Expression Toilet Replacement Flush Assembly
I need to replace my flush valve assembly 83420 (Porcher 1 piece toilet) this part is no longer available so were can i find a part that fits on that toilet... Thanks in advance
  • 297 Answers
SOURCE: flush valve
it is all one piece,replace it with the same model. a plumbing supply house is the only place you will find what you need.
Posted on Jul 15, 2009
smokenic
  • 49 Answers
SOURCE: K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
Posted on Sep 20, 2009
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
  • 1206 Answers
SOURCE: I have a Porcher one-piece toilet with a bad
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
Posted on Jan 06, 2010
ExHandyman
  • 86 Answers
SOURCE: My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Posted on Apr 09, 2010
Where can I get a Porcher L'Expression flush valve gasket?
I was in the same situation. Cost me $2.38 to fix. Ordered 12" x 12" rubber sheet from Sustainable Supply and made my own flush valve. Easier than I imagined. All I did was trace the old flush valve on to the sheet with a Sharpie and cut it out with a pair of scissors. Yep, it was that easy. I ordered the 1/32" sheet and it worked on the first try. I would order the 2/32" next time because my handmade flush valve is a little thinner than the original; however, it works perfectly. I was shocked. I had searched the Internet and called all places I found and then decided to give it a go on my own. Here are the specs....it works.
Sku: C1749648
Rubber, Buna-N, 1/32"Thick, 12"x12", 70A - 4070-1/32A
Jan 21, 2016 | Porcher 83420-00.000 L'Expression Toilet...
How do I replace a veneto flush piston in my toilet?
The piston sits inside the upper valve housing. The upper valve housing comes off by twisting the upper housing counter-clockwise. When you lift the valve housing out of the tank you will see the flush piston extruding from the bottom of the housing. The flush piston can be pulled out of the housing.. Yes, it just pulls out. And you just push the new piston in place.. Secure the valve assembly back into the tank by rotating the housing clock-wise.. Some Veneto toilets have two clips on the housing which secure the housing in place.
Jul 11, 2014 | Porcher Home
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
I need a replacement flapper for a St Thomas Creations enhanced height elongated 1 piece toilet
Did you try to find a replacement flapper by specifying the toilet model, or did you show them what you have? If this is not a power assisted flush toilet, there aren't that much difference between flappers. Worst case you could replace the whole flush valve assembly with a generic type.
Oct 18, 2012 | Seth Thomas St. Thomas Creations 6006.130...
Porcher Toilet Lid Hinges are loose
Tinkerbellpp is right about the 70032-00.001being out of stock. You can replace this with the 70030-00.001(chrome hinges) seat which will fit the Veneto Toilet. You can find this at your local dealer/showroom. Hope that helps!
Aug 29, 2012 | Porcher Toilet Seat Veneto 70032.001
Where do I get porcher 83420
Hello--
That particular model has been disontinued; however, you may want to contact Customer Service to see if there are any spare parts in stock.
http://www.porcher-us.com/contact.aspx
Paul, ASB
Sep 20, 2011 | Porcher 83420-00.000 L'Expression Toilet...
OCCASIONALLY HEAR SMALL LEAK COMING FROM BOTTOM OF TOILET...WATER BILL UNUSUALLY HIGH...(FAINT HISSING SOUND)
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl through the flush valve slowly...causing the tank to drain and the fill valve to run every few minutes or so. start by inspecting/cleaning or replacing the flapper and hopefully that will do it because a one piece toilet flush valve needs a special wrench,to remove it, that you use with a ratchet. If you buy a new flush valve, it comes with the wrench (glorified piece of plastic) and is not too difficult to get the flush valve out. you can get a replacement at http://www.plumbingpartsdepot.com/ They do mail order, too. All you need is the toilet type - a four digit number embossed in the tank starting with a 2. hope this helps but if you need anything else just ask:)
Jul 29, 2011 | Porcher VENETO II One-Piece Toilet -...
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Porcher 83420-00.000 L'Expression Toilet Replacement Flush Assembly Logo
192 people viewed this question
Top Porcher Home Experts
Donni Steen
 John
John
ray gallant
Are you a Porcher Home Expert? Answer questions, earn points and help others
