Question about Vintage Keeper 250 Plus Wine Cellar
Doesn't cool. Compressor and fans working. Low on refrigerant-accessed the refrigeration system, and put R134 gauges on access valve and we are reading zero pounds of pressure. Should we consider a new refrigeration unit because leak is not obvious and not completely empty? Very difficult to find the leak. If we need a new unit, how can we get it?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: with compressor running, low side pressure starts
Wow, it would seem like you have a leak there on the low side. You add and it goes goes back to equal on the low side again. The gauge could be off just a bit. Have you pulled a vacum test on the unit? Sounds like you should pull everything out, vacum and the weigh in the correct charge at this point assuming that you do not have a leak or can find and fix it.
Posted on Nov 15, 2009
  • 2187 Answers
SOURCE: I have a Vintage Keeper
Have it checked on how much refrigerant yo have left before deciding on the purchase of a new unit or recharging it. The cost may be far and from there you can decide on which is more practical. It may also just be a faulty thermostat.
Posted on Apr 06, 2011
Lincoln MKT - air conditioner won't stay cold
It could be any of a number of things:
  • Low refrigerant. An A/C system requires a certain amount of refrigerant to cool properly. If low, it works less efficiently and does not cool well.
  • Dirty condenser -- The condenser is the heat exchanger mounted in front of the radiator. It cools the high pressure refrigerant vapor after it exits the compressor so it can condense into a liquid. If the condenser is full of leaves, bugs and road debris, air flow through the unit may be blocked to the point where little cooling occurs. Cleaning the condenser should cure the problem.
  • Inoperative condenser cooling fan. The condenser often has its own separate electric cooling fan. This fan should come on and remain on when the A/C system is operating. If the fan motor, motor relay or wiring is defective, the fan may not be working.
  • Air or moisture contamination -- For the refrigerant inside the system to do its job properly, it must not be contaminated with air or moisture. Air reduces the cooling efficiency of the system while moisture can freeze and form ice that causes blockages in orifice tubes and metering valves. Air and moisture contamination may be the result of unrepaired leaks in the system, or failing to vacuum purge the system prior to recharging it with refrigerant.
  • Blockages -- Debris, rust or debris in the system may plug up the orifice tube or metering valve that admits refrigerant into the evaporator. If this vital point becomes obstructed, the flow of refrigerant may be restricted or blocked causing a loss of cooling -- and possible compressor damage as well in systems that rely on oil circulating with the refrigerant for lubrication.
  • Mechanical problem -- These include things like metering valve failures, compressor wear, a compressor clutch that fails to engage, bad pressure switches, etc.
  • Jul 16, 2011 | Air Conditioning and Heat for Lincoln MKT
    Air conditioning stopped working suddenly. power not getting to clutch . fuse ok
    It could be any of a number of things:in your case I would look under the hood at the fuses and relays there , here are some other things
  • Jul 14, 2011 | Air Conditioning and Heat for Toyota...
    Air conditioner turns on but no air comes out. does it works with a fuse or sensor if so where is it located in the scion tc 95. can someone help me or list the possibles problems that i can look out for...
  • Jul 14, 2011 | Air Conditioning and Heat for Scion xB
    AC COMPRESSOR CLUTCH WON'T ENGAGE.
    It could be any of a number of things: be sure and check the fuses and relays under the hood in that fuse panel , also the mail switch inside ,, you can jumper those contacts to see if it's the switch , here are some other ideas
  • Jul 13, 2011 | Air Conditioning and Heat for Hyundai...
    How to recharge recharge airconditioner
    Hi, determine if your car uses R134 or R12 refrigerant. You will notice screw type connectors on the both the High Pressure Side and Low Pressure Side lines in models using R12 refrigerant. R134 compatible models have quick connect valves on both sides. Models made before 1995 may use the old R12 refrigerant. If this is the case, you must have your Chrysler's air conditioning system retrofitted to use R134 refrigerant. Mixing R12 and R134 refrigerants is dangerous and may cause damage to your vehicle. Check your air conditioning system pressure using an automotive air conditioning pressure gauge. Keep in mind that in order to get an accurate reading, the air conditioner has be turned on the coldest setting with maximum blowing power. Remove the Low Pressure Side port valve cap and set it aside. The location of the port varies, but it is usually in front of the engine block. Attach the refill hose to the port on the Low Pressure Side of the air conditioning system. The Low Pressure Side port is smaller the High Pressure Side port. Because the ports are different sizes, the refill kit hose should fit only on the Low Pressure Side port. Additionally, the High Pressure Side port will usually have a red cap or be marked with an H or the word High Allow the air conditioner to **** the refrigerant out of the can by slowly turning the valve on the refill kit hose. Pay attention to the way you hold the can. Most kits will have you hold the can upright when you recharge the air conditioning system. It may take as long as 10 minutes to empty a single can. Turn the valve to the off position and remove the refill hose from the port. Recap the port before closing the hood. Let the air conditioner stay on for at least 30 minutes. This allows the refrigerant to move throughout the entire system.
    Take care
    Aug 03, 2010 | 2006 Chrysler Town & Country
    Doe s anyone knows how to charge R12 Ge model
    Keep looking for the access on the high and low side. Some of the valves look a little different but you should be able to find where to hook the gauges. R12, R22, and 134a all charge the same way and use the gauges and hoses. just make sure you have pressure temperature chart.
    I hope this helps
    Apr 20, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
    FACING THE CAR, WHERE IS THE EXACT LOCATION TO ADD FREON TO A 1997 CHEVY MALIBU. WE FOUND A RED CAP BUT UNDERSTAND THIS IS NOT WHERE YOU SHOULD ADD. HELP .....
    The low pressure refrigerant port is near the firewall2.gif, just after the receiver/dryer. You'll need a gauge and preferably an ac test manifold. You can use the manifold to add refrigerant up to the point where the system maintains the pressure level in the green area. There should be a blue cap on the low pressure valve.
    I believe your malibu take's 12 ounce's of R134, don't over charger the system. You'll blow O rings and worst kill the A/C compressor.
    Good luck and hope this helps. Here is a link for A/C recharging. http://www.geocities.com/vantaray/air_conditioning.htm
    Aug 19, 2009 | 1997 Chevrolet Malibu
    Dometic Quick Cool compressor freezing and evaporator coil
    Could be low. First check air filter, air flow, and evap coil to see if it has restricted airflow. If all seems well, its probably low. The specs will tell you what type and how much refigerant. To access system, you will need a gauge/manifold set, refrigerant, and a piercing or line tap valve for the low pressure side of the system. Of course, first, you need to locate and repair the refrigerant leak.
    Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
    1993 buick century
    Heater Control Module
    May 31, 2009 | 1993 Buick Century
    Lights, Fan, Compressor all seem to work. Compressor is HOT.
    Anytime you have your symptoms, you are so low on freon that there is no perceptable cooling. If you can put your hand on the compressor "high side" (discharge side and also the smaller refrigerant tube exiting the hermetic compressor) while the compressor has been running a few minutes and it is not hot or very warm to the touch, you are low or out of freon. Refrigerators do not normally utilize expansion valves but have capillary tubes at the inlet to the evaporator coil, which would normally eliminate possible trouble. If your refrigerator does have an expansion valve ahead of the evaporator coil, it could be the culprit, if it "sticks" closed, preventing refrigerant from circulating.
    Usually when a refrigerant circuit begins to loose freon, you first notice that "frost" may begin to form on the evaporator coil (refrigerator side). Look in at the rear inside panel of the refrigerator to see if there is a layer or buildup of ice / frost on that panel. That is a sure sign that you are low (but not out of freon).
    Usually, there is already a freon service valve for adding refrigerant.
    If you are mechanically inclined, I could give you more detailed instructions to "charge" your refrigerator. You must have a freon can tap (for the appropriate refrigerant), a refrigerant hose that mates with the "access valve" on the compressor and to the freon can tap / valve.
    Jan 02, 2009 | Kenmore 53642 / 53644 Side by Side...
    Vintage Keeper 250 Plus Wine Cellar Logo
    32 people viewed this question
    Top Vintage Keeper Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
