Question about Sub-Zero 690 Side by Side Refrigerator
The ice maker doesnt make ice and the vacuum condenser warning always is on. even when I turn off and on and vacuum
  • 3,083 Answers
Your unit may still be under warranty- the following blog has the warranty lengths (in years):
http://applianceguru.com/forum1/16671.html
Here is a general ice-making troubleshooting guide that may help you:
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
Here's what a tech on applianceguru.com says about the vacuum condenser problem:
The vaccuum condensor light just means one or more compressor in the unit has excessive run time, you need to have this unit checked, your compressor(s) are running too long for some reason so might be a sealed systen problem developing.
Read more: Subzero says vacuum condenser - The Kitchen Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum1/2410.html#ixzz14kiAdO9r
Get appliance parts at http://parts.fixitnow.com Since you have a sealed system, a tech will have to come check it out and troubleshoot it. Hope it's still in warranty, and good luck.
Posted on Nov 09, 2010
Have replaced everything and ice maker still doesnt work model ed5shaxmb10
An ice maker has 3 basic tasks:
1. Call for water.
2. Freeze.
3. Harvest.
Then the cycle repeats. There will always be some sensors that determine timing of those tasks. Home units usually have a bin level sensor (often an arm that's lifted as the bin fills) that can be locked in the up position to disable the ice maker.
If it's calling for water but not freezing, make sure the condenser is clean. (Sometimes they look clean but are plugged in the middle.) It has to get down to nearly 0 degrees to efficiently make ice, if it's not getting cold enough you may need a tech to figure out why.
If there's ice in the tray but it's not harvesting, clean the tray, hard water deposits can make the cubes stick in the tray.
May 26, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Tip
How You Can Get More Ice From Your Ice Maker?
The modern tech era is launching various new machines and technologies with which we can enhance the productivity of products and services. Modern ice makers like clear ice machines and portable ice machines are one of them. These ice machines not only help to make clear ice cubes but also we can generate more ice cubes in less time. Following are the main ways by which you can create more ice cubes from the portable ice machine:
    Ambient temperature- If you keep your portable ice maker in the cool environment, then you won the bet as the increase in degree will decrease the fast production of ice cubes.
    Clean Condenser- This is also important to keep your condenser clean all the time. The dirty condenser takes much time and uses more power In comparison to the clean one.
    Chilled water- If you pour chilled water in the ice tray then it will make the ice too faster.
  1. Regular maintenance- Most crucial way is to keep your freezer in a right situation as any fault in the machine will make the ice cubes slowly, or even it can stop making cubes.
https://icemakershub.com/best-portable-ice-maker-reviews https://icemakerpartsshop.com/blogs/service-support/15597885-how-to-clean-an-ice-machine-air-condenser
on Jun 01, 2018 | Kitchen Appliances - Others
How to clean a scotsman icemaker
WHAT SHOULDN'T BE DONE.
Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
WHAT SHOULD BE KEPT CLEAN?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
HOW TO CLEAN THE CABINET.
Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
HOW TO CLEAN THE ICE STORAGE BIN.
The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
HOW TO CLEAN THE CONDENSER.
The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
1. Remove the kick plate.
2. Locate the condenser surface.
3. Vacuum the surface, remove all dust and lint.
4. Replace the kick plate.
CLEANING THE SYSTEM.
HOW TO CLEAN THE ICE MAKING SYSTEM.
1. Open the door and turn the ice machine control knob off.
2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
4. Turn the ice machine control to ON.
5. Allow the machine to operate for about 2 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin interior.
10. Replace the ice removed in step 2.
The ice scoop should be washed regularly, wash it just like any other food container.
WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
May 16, 2014 | Scotsman DCE33PA1BC 15in Built-in...
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Ice machine keeps going to "off" mode. detects full harvest but no ice made. also condenser fan doesnt seem to be working.
o[en bin and look at your sensors, more then likely they have a scaley build up. the sensors are located below the ice maker and before the bin. It looks like a button of sorts one on each side, you can use a tooth brush to clean them. This should fix the problem
Jul 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
Sub zero 690 ice maker
also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
Jul 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
No water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Jun 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Freezer not cold enough to freeze items solid
    Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
    Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
    Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
    Sub-Zero 690 Side by Side Refrigerator Logo
    165 people viewed this question
    Top Sub-Zero Refrigerators Experts
    Sal De
    Steve Allison
    Steve Allison
    Archie Ferrarini
    Archie Ferrarini
    Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
