Question about Minolta magicolor 2200 DeskLaser Printer
Getting the msg "service call 22 man tray lift"...
    Scholar:
  • 79 Answers
This service indicator is referring to the main lift motor that is located on the rear of the machine, which comes in contact with the back of the tray and then engages to lift the paper up to the tray. I would suggest removing the paper tray and inspect the back of it, ensure that no parts appear broken and attempt to manually crank the arm that causes the paper to lift. If all is functioning on the tray side, then look towards the back of the machine through the front, make sure there is no lodged paper or debris. If no physical obstructions are present, and nothing appears to be broken and the paper tray aligns up properly, then you most likely have a failing lift motor.
Let me know.
-David.
Posted on Nov 09, 2010
How can i get the error 15 msg off my Kenmore Refrigerator panel?
Contact the service man and have him make it right with you.
Dec 11, 2014 | Kenmore Refrigerators
Have canon mp610 printer....wont print . msg "service error 6AOO " Have switched off printer , does not correct fault. thanks
Welcome to Fixya.
Here are the items that you can try to resolve this problem :
  • Uninstall the printer driver via (Windows) : Control Panel/Remove programs
  • Restart your computer
  • Download the updated driver from the below link. Choose your operating system then download until it's complete.
  • Launch the setup application after download and follow on-screen instructions
  • Restart computer
Canon Updated Driver
Thanks for using Fixya.
Jul 06, 2011 | Canon Office Equipment & Supplies
Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Mar 12, 2011 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Misfeed in tray one with no misfed paper. The machine is trying to grad from tray one but cant.
Pull out your paper tray (instructions below) and make sure there's not paper behind the tray blocking the motors from operating.
Else, worn rollers or broken lift motor.
First go to the service sim mode with the key combo # * C *
Type 22 - Start 9 - Start
If your tray 1 counter is above 100,000 your 3 rollers need to be changed. This is easily done by taking out the tray (you must tilt to the left and lift up at the end), unclipping and removing the paper guide, and unclipping and removing the 3 paper tires.
If your counter is under 100K try washing your rollers with soap and water, rubber cleaner and alcohol if you have it, but not Windex or 409. Your matched set of feed/sep tires should have some rough tread on them, if they are baby **** smooth its' replacement time.
If it pulls paper from a fresh stack and then stops pulling after a few sheets, the motor that continunally lifts the paper stack to meet the rollers has broken down, and can be replaced from the back of the machine.
Dec 30, 2010 | Sharp MX-3501N All-In-One Printer
We have a Konica Minolta Di2010 - we are getting a message on the screen that read: "A malfunction was detected. Please call your tech rep with this code: C0920" What can I do to get the...
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
WheatlandServices
Dec 16, 2010 | Konica Minolta Office Equipment & Supplies
Just cleaned our Thermador BICM24CS Coffee maker but we get an error message "empty trays". I emptied them, cleaned the contacts, reset the start button. Still has that error msg. If I remove...
Did you ever figure out a 'fix' for this? I am about to take a sledgehammer to this machine - the 'empty tray' message is preventing us from using it at all!
Dec 16, 2010 | Thermador BICM24CS Espresso Machine &...
I have a canon 6080 scanner. getting a error "no
Clean the two 'black dots' in the paper tray, just under the roller. They are actually paper sensors. Try 'page counting'. If this works, the scanner is okay. If the problem still persists, try reloading the scanning software.
S. Mohan, Chennai, India
Nov 17, 2010 | Canon DR-6080 Path-Through Scanner
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
F3 ERROR CODES
This code indicates a fault with the paper tray lift-up motor. F3-12 = tray 1, F3-22 = tray 2 etc. To clear this fault switch off at the power supply and empty the indicated tray of all apaper and jams. Operate the lift up section and then close the drawer with NO paper in drawe. Switch on again and after the machine boots up replace the paper in the drawer. This usually works fine unless there is a serious problem with the lift-up motor.
Feb 19, 2010 | Sharp AR-5320 Black and White Copier
Minolta magicolor 2200 DeskLaser Printer Logo
202 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
