Question about Micro Innovations PD950P Mouse
Lights up but when i move it around my cursor will not respawn to my movements.
    Guru:
  • 2,178 Answers
Press the "connect" button on the bottom.
Posted on Nov 09, 2010
Pen cursor moves in opposite direction than its suppose to
Use your pad in the other direction or invert the cursor movement in mouse settings......
Dec 26, 2013 | Monoprice 8x6 inches graphic drawing...
Acer aspire 5520 mouse pointer problem it freezes or moves around the screen by itself
Glad to HELP YOU!
First of all try to clean your touch pad with a SOFT CLOTH gently soaked in a GLASS CLEANER fluid. Make that as good as you can and you will remove all the dirst that may occur during the function of your computer, generating "fake movements" of the cursor.
Second: go to
START > CONTROL PANEL > MOUSE icon > DEVICE SETTINGS
and disable touch pad or check box to hide cursor while you are typing.
GOOD LUCK!
Apr 15, 2011 | Acer Aspire 5520-5908 Notebook
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
How do you navigate the main screen
Maybe I am not understanding the question, but you normally would use one of the remotes, make sure the receiver bar is either at the top of bottom of the screen and use the remote pointed at the screen to move the cursor around, click on the desired object using the A button on the front of the remote.
Remote has to be pointed at the screen for the cursor to move around and any movement you make will move the cursor.
Sep 08, 2009 | Nintendo Wii Console
Cursor jumps around screen when typing
your dell laptop are supposed to have a program on touchpad, if you dont have that in your system then the touchpad is jumping
Jun 17, 2009 | Dell Latitude D630 Notebook
Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
May 11, 2009 | Computers & Internet
While I am typing on the keyboard the cursor will skip around in my document. I find that if I do not watch closeley, my indented document is a mess. All the parts are there but they are scrambled.
A couple things can cause this to happen....
1. While you're typing, your hand or thumb might be hitting the mouse area near the keyboard which causes the mouse to move around.
2. You could have some heavy resource program running in the background which slows the system down.
3. You have an infrared mouse without a proper mouse pad so the infrared causes the light to bounce around causing issues.
4. A virus :(
Apr 02, 2009 | Dell Inspiron 1000 Notebook
Game keeps jumping me around
If its only in online and not in single player then the only thing it can be is lag, there must be a bad connection from your router to your xbox maybe you're using wireless and its too far away from the xbox? Hope this helped.
Jun 02, 2008 | Microsoft Xbox 360 Console
Dell ms intellimouse vertical movement of cursor
open the mouse remove the ball you should see two support shaft for the ball check whether they are rotating clean them if you can
if they rubber shield of shaft is damaged try replacing them with valve tube you usually use in a bycycle tyre
clean the transistors standing near the shaft flywheel using a soft cloth
it will be fine
Dec 14, 2007 | Dell Microsoft Intellimouse
Micro Innovations PD950P Mouse Logo
123 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
