Question about Hobart SR24C-5 Dishwasher
Hello. I have a 1993 Hobart LX-30 dishwasher. Just recently the door lost the tension it has when we open it up. it now is extremely heavy and falls open like a dead weight. Any ideas what might be the cause and how it can be fixed?
    President:
  • 1,140 Answers
There are a few possible causes of this, so it's easier to explain how it works and how to find the fault. There is usually a wire or cord attached to each hinge. The cord is threaded anti-clockwise through a pulley then runs vertically up to near the top of the washer where it's attached to a spring. When looking at the side of the washer, the spring is usually about 2-3 inches back from the door and attaches about 2-3 inches below the top of the washer.
To find the fault you need to remove the side panel/s of the washer. It helps if you can identify which side has lost tension (it could be both) as this avoids removing one side panel unnecessarily. Once you have removed the panel, you should be able to see the back of the hinge and the pulley/cord/spring assembly. It should then be fairly obvious what the fault is - it could be a detached/stretched/broken spring, or a detached/broken cord.
Hope this helps.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Posted on Nov 09, 2010
How to fix door on hobart lxih dishwasher?
Check the door hinges.. if a hinge is broke or the door came off the hinge it won't shut.... now if the door won't stay closed then the tension bar that is on the door, connecting to the hinges is broke and you will have to replace it
Jan 26, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I was given a lx 30 hobart when i hooked it up i got a p1 then it spelled out d r o p can you tell me what this means thank you
P1 means a temperature probe reading is out of range, I believe it refers to the temp. probe in the sump inside the dishwasher. There are also P2 and P3 which refer to the booster tank temp. probe and the rinse water temp. probe. Remove the lower front panel and make sure the connector going to the sump temp. probe (two small black wires) is connected well and the wires look OK. Replace the temp. probe and P1 should go away.
"DR" followed by "OP" means "Door Open". If this is displayed when the door is closed, you most likely need to replace the magnetic door switch. Open the door and remove two phillips head screws which are installed vertically, holding the control panel drawer closed. Then open the control panel drawer (sometimes it's kind of stuck,but not usually). The magnetic door switch (i.e. reed switch) is located on the right side of the drawer, held down by a small metal bracket. Of course it's possible your problem could be the magnet in the door itself, but most likely the door switch is the problem.
Mar 02, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Door tension spring broken.
The columbus hobart branch should have this part.Need any more info let me know.
Dec 08, 2008 | Hobart 41 in. AM14-255 Free-standing...
Hobart mixer 30 quart
this is an extremly difficult mixer to take apart if you are not tech minded do not attempt this
Nov 29, 2008 | Hobart A200 Stand Mixer
Hobart dishwasher lx 30 h
Did the clean light indicator blinking over n over? check the element wire harness connector. If disconnected fix it and run your dishwasher again.
Also you may check the continuity of your heating element.
Jul 23, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart SR24C-5 Dishwasher Logo
175 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
