Question about Samsung Galaxy S GTI9000 Smartphone
I reset my samsung gt-i550 galaxy 5 android and i cannot connect to wi-fi
    President:
  • 1,010 Answers
If you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.
Posted on Nov 09, 2010
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
My samsung mobil GT- i9003 is locked
Thank you for providing all the info! Greatly appreciated!!
Now on to a solution. You can try to do a factory reset. You don't need to log into the phone in order to do one. However, this WILL erase everything on your phone, and revert it back to when it was originally purchased. Not sure if the unlock will remain.
To do a factory reset:
1) Turn off your device
2) press the power button and the volume up button simultaneously until it takes you to a new menu.
3)Use the volume keys to navigate, and the power button to select (Exact directions are provided on the screen)
4) Look for an option to "Wipe/Factory reset" (Note: It might be located in a sub menu, and not actually on the first screen.)
5) Select that option and press the designated "OK" button. (usually the power button).
6) Phone will reboot and you should be able to get back in.
Hope this helps!!
Jun 22, 2014 | Samsung Unlocked i9003 GT-i9003 4GB Galaxy...
Why is my linsay tab is stuck on the reboot screan
There might be problem with your firmware version of the device.
Do a hard reset of your device, hopefully it will be solved. Here is the instruction:
Suggested From: Samsung Galaxy S6500 Unlock Code Sim Network Pin
Performing a Factory Reset on Samsung Galaxy S6500:
1. Hold both the volume up key and the power key at a time to start the phone.
2. Command to Factory reset /wipe data>>>delete all user data>>>reboot system now
3. HARD RESET COMPLETE.
How to Hard (Master) Reset?
1. Select "Menu">>> "Settings."
2. Go to "Privacy">>>"Factory Data Reset".
3. "Format USB Storage" CONFIRM TO CLEAR DEVICE..
4. "Reset phone.">>>"Erase Everything" confirm to reset to factory settings.
Jun 22, 2014 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
To many patten attempts
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
Reset password
unlock screen black samsung dous gt s6102
Aug 19, 2013 | Samsung GT-S6102 Galaxy Y Duos Dual SIM...
Reset password
Hi.
we have samsung galaxy y dous screen lock and forget google mail id password
what i can solve this problem?
pls suggest me
welldonefabric@gmail.com
Aug 13, 2013 | Samsung GT-S6102 Galaxy Y Duos Dual SIM...
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
I have Samsung Galaxy 5 GT-15503. Android 2.1. After full charge if I use it ,WI-Fi enable. Battery does not more than 2 hours. If Wi-Fi disabled battery last long. Why??
Wi-fi has been known to eat up the battery life on ALL devices it's on.
That's just the way it functions.
If you really want to save battery on your phone, disable wireless, bluetooth and 4G connections you may have, dim the screen to it's lowest setting and change the display timeout to a very low time.
Mar 10, 2011 | Samsung Cell Phones
Samsung Galaxy S GTI9000 Smartphone Logo
2,295 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
