Question about Dishwashers
Kitchen Aid Dishwasher model # KUDK03CTSS3 The control panel lights are blinking rapidly, several of them. Nothing works, even after powering off and on again. I see there are instructions to reset the control panel on these before calling for service. How do I reset the panel on this model?
SOURCE:
SOURCE: Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Posted on Jan 21, 2008
  • 1314 Answers
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
huuum
  • 750 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Hi 1cassie1,
Did you try to turn the power off at the breaker box?
This resets the whole system usually!
Let me know how it goes? Write me back!
Other wise you need a hands on tech.
ngafm
please give me a rating before you sign off!
Posted on Sep 11, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
What is the reset sequence for a Kitchen Aid Dishwasher KUDK03CTSS3?
Dear Sir:
Please follow the step in your instruction manual for to reset.
if you do not have the instruction m go for free download:
www. fitness.manualsonline.com or www. retrevo.com
anyway go to this page and see for reference:
http://www.ehow.com/how_4899022_reset-bosch-dishwasher.html
sincerely.
May 06, 2012 | Dishwashers
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Detergent is left undisolved in bottom of washer when cycle is completed. Water pressure is correct. No cloged pipe. What is happening? No excess detergent. Kitchen Aid dishwasher. Imperial 21 series
I have the kitchenaid KUDK03CTSS3 dishwasher with the same problem, it doesn't take the detergent. Have you been successful in finding a solution?
Jul 07, 2010 | KitchenAid Dishwashers
Hi! I'm having a problem with my dishwasher its a Kitchen Aid Mod # KUDK03CTSS3 It's is just rinsing the dishes then stops completely and the start/resume button flashes!
have you found a solution? i have the same model and it won't take the detergent and only rinses the dishes. please let me know! thanks.
Sep 26, 2009 | KitchenAid Dishwashers
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Jan 26, 2008 | Kenmore 15912 Built-in Dishwasher
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Blinking normal and cancel lights
I had the same problem- needed a new control panel. good luck. Didn't bother going through kitchen aid even though its still under warranty- figured they'd nail me on labor (it's in the 2- 5 yr warranty period) and I'd be waiting forever. had a private appliance tech take care of the problem.
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
