Question about Pioneer DEH-1900MP CD Player
Stereo display works fine, but no sound to speakers.
I have a Pioneer DEH-1900MP hooked up in my boat. Speaker wires appeared to be hooked up correctly and stereo display works, but there is NO sound going to the speakers. It worked fine the other day. I hook up the speaker everytime I use the boat, then unhook them when I'm done, but the speaker wire gets wet. I'm using monster Cable. Would there be a problem with the speaker wires getting wet?
Not using an amp...I go directly from the stero to 2 speakers.
Thanks!!
    Scholar:
  • 55 Answers
The wires may have gotten wet and fried something in the sound output in the stereo.
Posted on Aug 30, 2008
  • 6,674 Answers
Be sure as well to check all power connections to stereo for possible blown fuse. Likely have 2 or more fused connections for power.
Posted on Dec 10, 2011
Speaker hook
Hi it's a problem in the set up . This model , like few other in the line have the possibility to switch the "back speakers" ( through harness or RCA) into "BASS SPEAKERS" what give you a possibility to hook up a Sub without an extra amp .
To switch it back just follow the Section 2 / Sw control of this link http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-3300UB_OwnersManual0902.pdf
Dec 19, 2013 | Pioneer DEH-3300UB Radio-CD-MP3-Digital...
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
I have a pioneer deh-p3700mp DC reiciever. It was working fine. I turned it on and no sound. I did find one speaker wire came loose. I reconneted it. No sound comes out of any speaker. It appears to...
if the loose speaker wire touched ground it may have blown the output ic. also make sure you have no other loose or shorted wires as this will cause the output not to work.
Oct 25, 2010 | Pioneer DEH-P3700MP CD Player
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
Stereo quit putting out sound
if it was working, then stopped, it may be a grounded speaker or speaker wire. If a speaker is blown, you may have damaged the internal amplifier. It will need repair.
You may have just hit a tone adjustment button like FIE or EQ where the settings at each frequency are changed based on the source you are listening to. If its not a big deal, pull the radio fuse and wait 5 minutes... or locate the reset button - usually behind the faceplate and start from scratch. This way you will know it wasnt a button pressed on accident
Dec 22, 2008 | Pioneer DEH-P6500 CD Player
Pioneer car stereo-how to hook up speaker wires
ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
Oct 01, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
No sound
I have a nessin maxima. Im trying to find a car kit for my car
Jul 23, 2008 | Pioneer DEH-1400 CD Player
I need help wiring a pioneer to a 1992 cavalier cuz the wires dont mach up
the cavalier wiring-top row is orange 12 volts regardless of the key switch position,yellow 12 volts when the key is on/or accessory, pink is for power antenna or factory amp turn on, grey is for lights dimmer control, black ground,green right front speaker +,light green right front speaker -,grey left front speaker +,tan left front speaker-, bottom row is brown left rear speaker +,yellow left rear speaker-,blue right rear speaker+,light blue right rear speaker- be carefull because you have 2 yellow wires and 2 grey wires if you follow the rows like I explaned you will be fine-If you need the wiring for the pioneer radio E-Mail me at merle840@aol.com
Apr 04, 2008 | Pioneer DEH-1900MP CD Player
No output from the left front speaker
using your flashlight bulb in one hand, hold the speaker wires to the bulb and then gradually increase the volume. If the bulb lights, the Pioneer is good.
Jun 08, 2007 | Pioneer DEH-P3500 CD Player
Pioneer DEH-1900MP CD Player Logo
618 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
