Question about Campbell Hausfeld PW2102 Gas Pressure Washer
What kind of oil do you use in a Campbell Hausfeld pressure washer pump? We are using my dads and we dont have an owners manual thanks
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
Posted on Nov 09, 2010
Need to see a diagram of a campbell hausfeld clean power 37 unloader valve
Most all of the manuals for campbell hausfeld tools are found at www.chpower.com , just look for your model number. Also , campbell hausfeld does not make all their pressure washer pumps. Yours may be another brand. To find who makes yours look on ebay. Make search for {pressure washer pump only} and look for one that matches yours. Then look for that breakdown. Good lu ck.
Oct 12, 2017 | Campbell Hausfeld Air Tools & Compressors
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Does a 2/3 HP .40GPM Campbell Hausfeld Airless Paint Sprayer require any kind of oil if so what kind and how much
airless sprayers have a pump that pumps the paint through a jet at pressure . there is no oil and it is vital that when finished that the pump be spotless after cleaning
Nov 12, 2015 | Campbell Hausfeld Air Tools & Compressors
What is average going price for a new or used wobble pump for a Campbell Hausfeld PW2200V1LE. My 6.0 Briggs & Straton engine is in very good condition Reason I ask is a brand new pressure washer in my...
keep the briggs if your just gonna use it for yourself get the sjv axial pump 239.00 put it on your briggs.many retail stores use s disposable pump no sightglass or drainplug sjv has forged brass head no pot metal.
Jul 30, 2013 | Campbell Hausfeld Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Sep 04, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
1,048 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
