Question about Fahrenheat Built-In Baseboard Thermostat Heater
Trying to install model FTA2A thermostat on correct heater but am having trouble with wiring.. I have 220 power coming in with black,white and copper wire. The copper wire I already put to ground but not sure hiow to hook up black and white wire to thermostat wires. Please help.
  • 55 Answers
SOURCE: hooking up the thermostat
Thermostats are typically low voltage only no more than 24volts that is supplied from the transformer in your heating unit. you need to look at your low voltage wiring that is in the furnace and write down the terminals that are hooked up. Usually (this is a very typical set up) red wire goes to R which supplies 24 volts. green goes to G powers fan motor, white to W terminal and blue or yellow goes to Y terminal this terminal will usually have another wire in its terminal with it to control an outdoor ac unit likely another red or white wire, and lastly the C terminal has a white wire. That is for a basic heating and cooling system just match how they are hooked up at the main unit to the terminals on your thermostat. the thermostat is just a switch breaking and connecting terminals that allow voltage to carry through it. Shut down your unit while working on it as not to blow the transformer otherwise you are gonna need to replace it to if it isnt fused, that is probably my most common repair from people who have tried to change their own thermostat. Hope this helps
Posted on Sep 21, 2009
dmftrucker
  • 1922 Answers
SOURCE: I have model#2509622 Williams wall
can you manually fire the unit w/o the thermostat by shorting 2 of the 3 wires, there may be more wires than that, but you should be able to fire it on 2 to 3 wires alone let me know it sounds like something is floating voltage wise on the unit
Posted on Oct 09, 2009
shastalaker7
  • 1515 Answers
SOURCE: i am trying to install a fahrenheat f2543 heater
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Posted on Nov 22, 2009
  • 449 Answers
SOURCE: I bought a 30" baseboard
get the right t-stat
Posted on Sep 03, 2010
  • 86 Answers
SOURCE: Im hooking up a base board heater for the first
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Posted on Nov 04, 2010
Tryin to conect 10-2 wire where does the black and white wire go.myou manuel does not explain it very well. Heater model #cz220
10-2 is for 220. White is neutral and black is power. You'll have to run a 10 gauge wire to the heater from your panel. Probably a good idea to hire an electrician as you make need to have a breaker added to your panel...could check/install if you need a wall thermostat. 220 is dangerous....
Mar 01, 2015 | Heating & Cooling
HOW TDO I HARD WIRE MY FISHER PAYKEL DOUBLE OVEN TO THE 220 THATS COMING FROM MY BREAKER BOX. IM TRYING TO TEST THE OVEN....IT HAS A GREEN BLACK RED AND WHITE WIRE COMING FROM THE FLEX OUT OF THE BACK OF...
Green and white from the oven go together and connect to the copper from the box, red goes to white and black to black. Be sure that it's 220 breaker your connecting to, for an oven it should be a 40 amp breaker, sometimes thirty
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 09, 2013 | Fisher and Paykel Washing Machines
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
Help with Thermostat Wire Connection
White from power source to white of fan. Black from power source to black (top of thermostat). Black (bottom of thermostat) to black of fan..... 120v. connections.....gs
May 18, 2009 | Electrical Supplies
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Fahrenheat Built-In Baseboard Thermostat Heater Logo
677 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
