Question about Verbatim STORE-N-GO (95312) 8 GB Hard Drive
I have a verbatim flash usb, the type that slides in and out. Simple question... should it stay temporarily locked when slid out for when inserting into usb drive? If I slide mine out then push to insert it just slides back into casing. The only way to push it in with the required force is to keep my thumb on the slide button. Is this normal? i would have expected no as it makes insertion into low usb drives on a laptop a bit fiddly.
    Scholar:
  • 79 Answers
This problem is not typical, as there is supposed to be two small plastic tabs that that slide into equally small indentations on the plastic that keep the drive out while in use. Normally the drive would slide out and lock, then, when you're done do push the drive back in. Appears to be defective or broken.
-David.
Posted on Nov 09, 2010
Unlock micro sd password
If this is a SD card, slide over the 'Lock' switch on the side.
If a USB flash drive - try RMPrepUSB - Drive - Clear Read Only Status.
Sep 19, 2013 | Verbatim 2GB Swivel Drive 96836 Media
Remove write protection on a verbatim flash drive
Ok I finally got it. It was so simple -_- Just open the V-Safe100.exe and click on the pink Settings button on the bottom left. There's a slider where you can adjust the PRIVATEZONE size and type in your password twice to reformat. Just make sure you back everything up first!
If you accidentally deleted the V-Safe100.exe like I did, just go download it back from http://www.verbatim.com/index/support.php?lang_id=1&cat=14&action=supportitems&pid=5463
Ugh, this thing wasted 3 hours of my life. But i guess it saves buying a new usb without the write protection.
Oct 16, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
Hello my micro sd card is saying write protection is on, could you please telll me how to disable this, thanks.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Mar 21, 2011 | SanDisk 1GB microSD Memory Card
I just bought and installed (Window vista) a sony 2.0 (4GB) but the window is failling to format it because it indicating that it write protected.
Hi Thanks for you question.
SOLUTION 1 - Unlock the memory card.
SOLUTION 2 - Toggle the lock switch.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
Jan 25, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
Hi I'm trying to add pictures to my sd card using the adapter that it came with but it's say that the disk is protected I didn't put any potection on it. I see a lock arrow on the adapter but I don't see a...
May 29, 2010 | PNY 2GB microSD Memory Card
Hi.. i hav a problem with Verbatim 8 GB usb drive,
they have lifetime warranty but not for the data. this is a damaged boot sector programming on the flash drive. It can only be recovered via a Level 3 data recovery company like ADR or Kroll. I used ADR.
Dec 28, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Computers & Internet Logo
77 people viewed this question
Top Verbatim Computers & Internet Experts
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
