Question about Dell E153FP 15" LCD Monitor
Not able to power up/on totally off LCD monitor 153fp
  • 11,361 Answers
Check for bad solder joints, fuses, transistors, caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Replacement board: http://www.lcdrepair.us
Posted on Nov 09, 2010
The monitor turns on, and 2 seconds later - turns off
Could be a power supply problem.
Disconnect from power source for 10 minutes and allow to totally cool down.
Reconnect and try
Jun 01, 2014 | HP 2509b Black 25 Widescreen LCD Monitor...
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 19, 2010 | ViewSonic VA1703wb Monitor
I have a dell 153fp and it is brighter at the bottom of the screen than the top. It also makes a very high pitch noise. Is there any fixes for these issues?
Check the lamp caonnector (white connector with pink and white wires ,or pink and black wires), look for arcing on the board around the inverter transformers. It sounds like the top lamps are not on fully. It can also be from bad soldering works at the lamps ends.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Dell E153FP 15" LCD Monitor
The monitor went dark, seems to have no power.
Totally darken the room your computer is in, and see if you can see a very-dim image on your computer.
If so, it could be the "inverter" part inside the LCD that has failed (about a $20 part, but will take a technician about $50 to $75 to disassemble/replace/reassemble/test).
Try connecting the monitor to a different computer, to see if the monitor is OK.
Try connecting a different monitor to your computer, to see if the video-card is OK.
Jun 23, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
HOW TO OPEN THE DELL MONITOR # 153FP BACK PANEL TO CHANGE THE BULB?
You have to remove the stand and use very thin flat balde screw driver to pop the front and the back panel apart starting at the bottom pf the unit. Are you sure that the back light lamps are bad? More likely to be the inverter circuits of bad capacitors in the power supply which is more likely, and if it does have bad caps, it will usually take out the transistors in the inverter circuit with it.
Nov 04, 2009 | Dell E153FP 15" LCD Monitor
Monitor totally blank
You have a power supply issue. Something is causing teh supply breaker to trip. You will need to find a local repair shop to pin point the issues.
Oct 03, 2009 | HP w1907 LCD Monitor
Dell E153FP 15" LCD Monitor Logo
74 people viewed this question
Alun Cox
