Question about Logitech EX110 SP CORDLESS Keyboard/Mouse
Will not type anything. Batteries have been replaced, USB checked for servicability and working, reciever showing conected
Conect
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts
hope this helps
Jan 14, 2011 | Computers & Internet
Computer not reading mouse
First.... Plug your reciever into another USB port, wait for it to install itself (Window 7, Vista) you'll know when you see the notification that you software has been sucessfully.
if XP, you'll need drivers by going to http://www.hp.com, select <Support> from top of page, right-most side. Click Driver Downloads and type your reciever model into the search box. Wait for a confirmation i.e.. a page showing a picture of your device and/or choices of potential devices with similar models; pick yours. However, I have not yet come across a wireless mouse or mouse/keyboard combo that didn't install itself.
Next: The Mouse Does Require Batteries. Be sure they are placed correctly; they go into the top of the mouse in older models (the part where your hand rests, slides back to reveal the battery compartment). Newer Models usually have a standard, common, battery compartment on bottom.
The optical laser bulb should light when the batteries are placed correctly. If the light (red in older models, blue in newer models), if no light, check/replace your batteries. No light, check your warranty.
Jun 13, 2010 | HP Wireless Optical Mouse
Just purchased it used. Both battries show
If the horn won't work, the batteries are dead. If the charger is showing green lights, most likely the gel inside the batteries has gone solid from the chair being stored for a while. Replace both batteries with type U1, 24v, 33 amps and see if that will clear the problem. The fuses are regular automotive type fuses.
Mar 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Dead keyboard. Yes! I have replace batteries, uninstalled everything, booted pc.
i just got off the phone with logitech tech support about my 'dead keyboard'. I have a logitech wireless keyboard/mouse ex100. the mouse still worked and the keyboard just quit all of the sudden like. THE FIX! 1. Make sure in your device manager that the keyboard is still connected and working properly. if it is...
2. then remove the batteries and type on the keyboard for 10 seconds or so.
3. Then reinsert the batteries.
4. press the left alt key, left control key, and the f12 key all at the same time.
5. Then press the connect button on the reciever
6. press the connect button on the keyboard
7. press the escape button on the keyoard
8. test the keyboard
it worked for me :) that's how i was able to type this. hope it works for you
Jan 04, 2010 | Logitech EX100 967499-0403 Keyboard
Just recieved a type 6 dreamgear wireless controller,doesn't work
1. Ask gifter/seller if it ever worked. If not, return it. What connect do you hit?
Apr 07, 2009 | DreamGear TYPE 6 2.4 GHz Wireless...
Logitech wireless mouse and keyboard are not working, i think that the reciever has no connection due to interferance. do i have to replace the reciever with a new one or is there a quick fix solution?
You can check to ensure you are not having problems with your USB port by checking Device Manager. Click on start>right-click My Computer>properties>Hardware Tab>Device Manager. If there is a Yellow! by one of the USB controllers then right click on it and click install drivers. You can also, uninstall drivers then reboot and your computers plug n play will pick the USB up automatically. Try it, its the quickest fix possible.
Don't forget to rate this solution.
Jan 12, 2009 | Computers & Internet
Samsung YP-T9 problem
look buddy first u shud get rid of the shorting out on the usb connection.
then get to samsung.com and check the support page of ur product and start downloading!!
Jan 07, 2009 | Samsung Yepp YP-T9 Digital Media Player
Usb Trouble
The USB ports all share a single power source. It may be that the Ipod being added overloads the connections.
You might want to consider purchasing a USB hub, but make sure you get one with a Power Adapter to boost the current to your devices.
Oct 01, 2008 | Microsoft Wireless Laser Desktop 4000...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
HP Pavilion DV8000 Laptop USB problem
did you try reloading the BIOS drivers?
Apr 03, 2008 | HP Pavilion dv8000z Notebook
Logitech EX110 SP CORDLESS Keyboard/Mouse Logo
26 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
