Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
No water is being picked up as I am cleaning.
Won't pick up water from the clean water side
I couldn't view u'r clip but it seems if the pipe is blocked try to remove the blockage by using a hose where you spray hot water and normal dishwashing liquid, through the pipe, to unblock it. Just do not immerse the whole machine in water! Because I do not know what machine you have. Good luck my friend!
Mar 23, 2013 | Vacuums
Tip
When I called they indicated that the brush roller can be removed with a...
Keep the brushes cleaned regularly. I used a pick to pull out the hair and dust bunnies. It took a while, but will be easier if done regularly.
I tend to want to wash everything with soap and water. They recommended not using water.
on Sep 23, 2013 | Dyson DC35 Multi Floor Digital Slim...
My Bissell Pro Heat Pet will spray water but not pick it up when cleaning the carpet. Is there anything I can do to fix it? The furniture attachment hose picks up water well. It seems like it could be a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 13, 2010 | Bissell Vacuums
I have a ProHeat Bissell 8910 Series. Won't release or pick up
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Doesn't pick up water
Is the vacuum motor running? Are the pathways from the floor tool to the recovery tank clean and clear?
Jun 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
Does not pick up the water after cleaning
heatman101
789iut
Nov 20, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat 2x TurboDoes not pick up the water after cleaning
heatman101
m,nb
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
382 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
