Question about Toshiba Satellite Pro L300 Notebook
How to remove cooling fan? whats anyparts of loptop can remove
How to change a coolant fan for a 2001 impala
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling fan.
  3. Raise and support the vehicle. Refer to Vehicle Lifting.
  4. Remove the transmission oil cooler lines from the retainers at the bottom of the cooling fan shroud.
  5. Remove the lower fan shroud push pin retainers.
  6. Lower the vehicle.
  7. Remove the right and the left engine mount struts.
  8. Remove the left front fender upper diagonal brace.
  9. Remove the radiator inlet hose from the radiator.
  10. Remove the air cleaner assembly.
  11. If equipped remove the cooling fan heat shields.
  12. Disconnect the cooling fan shroud electrical connectors.
  13. Remove the cooling fan shroud bolts.
  14. Disengage the cooling fan shroud clip from the top of the radiator.
  15. Remove the cooling fan shroud.
Aug 25, 2014 | 2001 Chevrolet Impala
What's the easiest way to change a cooling fan
There is only one way. Remove the bolts that hold the fan assembly on and removed the fan assembly. You may have to remove the upper radiator hose for clearance.
Aug 17, 2013 | Cars & Trucks
Can u replace fan board on a rheem with a fan relay switch
Yes, you can, but it's extremely detrimental to the unit - the fan will run continuously and the thermal functioning point of the cooling circuit will be way off the recommended range. Use that as a temporary (less than a week) and last resort solution.
Sep 29, 2011 | Ruud UAKA037 Air Conditioner
My asus k40in laptop cpu fan turns on only when it wants to. it doesnt help much in controlling the temperature. how can i turn it on continuosly like other laptops do.
hi my name is rui it does happen a lot i suggest that you buy a external cooling system for your loptop try it. well i got a friend thats pc is on 24hrs w/a cooling system helps alot even if the internal fan is not working.,
Jul 21, 2011 | ASUS K40IN Notebook
My loptop keeps restarting every 5 minuts
If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
May 20, 2011 | Toshiba Computers & Internet
The loptop is working fine.the fan never shuts and loptop stays hot to touch then shuts off.its 2 years old.
hello danilo dungo!
seems like your cpu is not getting enough ventilation. disassemble laptop and clean all parts affecting cooling, even the fan, reassemble and try again.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
regards
Feb 20, 2011 | Computers & Internet
How do i replace the radiaor? on this 2005 Hyundai do i remove the intake cover, then the cooling fan, the the motor mount? what?
Below are instructions and a diagram for removing the radiator from your Santa Fe. There's nothing involving the motor mounts. Best of luck and please post back with any questions or just to rate the solution. Greg
  1. Drain the cooling system. Remove the radiator cap to speed draining.
  2. Remove the inlet hose from the radiator.
  3. Remove the transmission oil cooler lines from the retainer clip at the bottom of the cooling fan shroud.
  4. Remove the fan shroud clip from the condenser tubes.
  5. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
  6. Remove the air deflectors from the top of the radiator.
  7. Remove the cooling fan shroud bolts.
  8. Remove the coolant reservoir hose from the radiator overflow neck.
  9. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
  10. Disconnect the engine cooling fan motors electrical connectors.
  11. Remove the cooling fan motors electrical harness from the fan shroud clips.
  12. Remove the cooling fan shroud.
  13. Remove the outlet hose from the radiator.
  14. Disconnect the transaxle oil cooler pipes from the radiator.
  15. Tilt the top of the radiator rearward.
  16. Remove the condenser hold down bracket from the radiator.
  17. Lift the condenser from the mounting tabs on the radiator and position the condenser aside.
  18. Remove the radiator.
Aug 11, 2009 | 2005 Hyundai Santa Fe
Overheating
It just could be in an enviroment that is too hot. Try using the laptop on a cool flat surface that does not block the vents in any way while in use. If the problem still persists you have 2 options, 1. Upgrade to a better heatsink/fan unit, or 2. Spend $20-30 on one of those laptop cooling pads and use it whenever you use the laptop. Hope this helps.
Jul 08, 2009 | HP Pavilion dv5-1140us Notebook PC
Toshiba Satellite Pro L300 Notebook Logo
181 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
