Question about Salton Toaster Ovens
Salton Model TOC-14A Convectair Oven-all of a sudden the glass front door will not close tightly-making it not usable for baking potatoes etc
  • 3,083 Answers
Something in the hinges and safety switch assembly is broken, or loose, most likely. You're going to have to take it apart to figure out what's jamming the hinge, and replace any broken parts. Getting parts can be a problem, but some companies off them.
First, figure out what's going on, then contact Salton support to find out if parts are available.
Good luck, and hope this helps.
Posted on Nov 09, 2010
How do I set a farberware t490c commercial tabletop convection oven to work
Try calling or emailing Farberware (distributed by Salton/MAXIM Housewares): faberware-electric@saltonusa.com OR 1-888-881-8101. Ask for Operating Manual
Dec 29, 2014 | Farberware T490C 1500 Watts Toaster Oven...
The bottom knob on my toaster oven broke. Where can I get a replacement knob? Thanks
Copy and paste the following address to get a list of websites that sell oven parts or try to contact the Salton company.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 27, 2011 | Salton 328BC Toaster Oven with Convection...
Why does Cuisinart TOB-40 produce steam and condensation on the glass door when toasting?
The bake/toast compartment is almost air-tight, creating an adequate seal to produce steam/moisture when the heat is applied to the water content of the food placed inside.
Mar 23, 2011 | Cuisinart Toaster Ovens
I need a New Glass door for my Salton Vitantonio VT6? The glass door completely shattered just past half way done cooking biscuits???
I would check with Salton and if that doesn't, here is an address that gives you a list of sites that carry oven parts.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 14, 2011 | Salton Vitantonio VT6 Toaster Oven with...
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Main problem, bottom two elements have conked out. Where do I get new ones? Next, how clean glass door when it won't come out of slots? Next, what do I use to clean shploops patina off crumb tray?
    you can get the new elements from the online sites mentioned below www.repairclinic.com also from www.partsselect.com and for cleaning follow this instructions
    1. 1)take out a bowl and in that bowl make a paste using the baking soda and vinegar
      2)After making a paste open the oven door with the oven off. Take the sponge dipping it into the paste of vinegar and baking soda.
    2. 3) After dipping it into the paste. Smear it on your oven door. Leave on for about 10-15 minutes longer for more stubborn stains. Now the time is up! take that sponge rinsing it in water and wipe down. Little or no elbow grease is required. Now you have a beautiful oven door.
      This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
    Mar 04, 2010 | Bella Cucina 13049 1500 Watts Toaster Oven...
    Recall: I bought a Euro Pro Convection/Toaster Oven w/Rotisserie and it caught fire today from a non-food related problem. Is there a recall on this item? There was no food in the oven and it was...
    Today I was warming up a baked potato in mine it was on 350for about 20 min when I went to shut it off the nob melted right off the ovenit was so hot I could not shut it off had to unplug it and the top of the ovenwas also very hot, is there any recalls on the MODEL # TO161
    Jul 11, 2009 | Toaster Ovens
    Toaster oven door will not close completely.
    This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
    To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
    Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
    1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
    2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
    3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
    4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
    5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
    6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
    7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
    8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
    9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
    10. Slide the left black side panel on to the SS tabs.
    11. Pry the left side black panel down until it meet the bottom plate.
    12. Replace the bottom screws.
    13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
    14. Replace the back panel screws.
    Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
    Farberware convection broil oven modle T-4850
    I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
    1-888-464-0797.
    Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
    Toaster Ovens Logo
    410 people viewed this question
    Top Salton Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Marvin
    Marvin
    ray gallant
    Are you a Salton Toaster Oven Expert? Answer questions, earn points and help others
