Question about Gateway Computers & Internet
I have an W3107 E Machine that has a bad motherboard...I understand that is is no longer available...what type of MB Can I replace the bad MB with?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 143 Answers
It may not be available from emachines. However, it may be available elsewhere. The part number for your motherboard is D33007 K8MC51G. If you want a different board, you can replace it with any microATX form factor. But you may then need to buy different memory, processor, hard drive, cd-rom drive, and/or power supply. By the time you get done buying new components you can possibly spend as much as you would for a new computer. So, my advise is to look for an exact match of your current motherboard. If you can't find one, replace your pc.
p.s. I searched your part number and found one here:
http://www.impactcomputers.com/4006107.html
Posted on Nov 08, 2010
Testimonial: "I appreciate your writing back and your assistance in findiing the part I need Thanks "
I need to buy a Multiscreen Card Colorgraphic Predator Type LT 4PCI 612304
It is going to be hard to replace the exact graphics card due to its age. Your best bet is to replace it with another graphics card that is compatible with your motherboard. The good news is many cards should be compatible with your board since there are very few connection types available.
Post which motherboard you have or simply do a search for what type of graphics card type/connection it accepts. I believe it will be a PCI or PCI Express type card. To make it easiest on yourself make sure the new card you buy has the type of monitor cables you would like to use.
There are really only 3 types it could use and most likely it will use a VGA (blue smallish cable that only accepts pins) and/or DVI (White longer connection with a square and pins).
Hope that helps.
Apr 16, 2014 | Color Graphics PREDATOR LT4, (16 MB)...
What if motherboard battery is bad
If battery is bad, computer will usually ask for time and date to be set every time you unplug the computer for a while. Most motherboard batteries are coin type CR2032 and are 3Volt lithium even available at your local Dollar Store. They can be tricky to remove and replace, so if you have no experience with this, it is best to get professional help or just look for some tips on-line. The instructions for your machine can be seen here:
eMachines W3107 User Guide Page 58
I suggest you follow the instructions carefully before proceeding. If you need more information about the instructions, you can download the whole manual.
Jan 16, 2014 | eMachines W3107 Motherboard Battery
Cannot find specification for packard bell i start 1379. I want to look into the possibility of upgrading this pc. Can anyone point me in the direction of the specs being available online for this...
Here is the homepage:
http://www.packardbell.co.uk/pb/en/GB/content/download
This specs provided was complete with a Intel Intel Serial ATA-300 ATA-133 PCI 160 GB Microsoft Windows Vista Home Basic , ATI Radeon Xpress 1100 128 MB 4 MB . The Desktops memory add up to 2048 MB , with standard memory 512 MB , memory installed 533 Mhz DDR2 SDRAM DIMM 240-pin Very low profile PC4300 Compact Flash Type I with 2 Expansion Sockets/Slots.
You can update the graphic, by adding a better graphic card, on the mainboard.
The ram can be upgraded to 2 gb ddr2 ram.
A bigger harddrive, can be added, for more space.
The cpu will be hard to find, it probably have socket 775, but this cpu is not available anymore.
And not all cpu`s will fit the mainboard.
Good luck
Feb 10, 2013 | Packard Bell (181368) Motherboard
My w3107 machine tower just beeps repeatedly when you turn it on and the hp vp17 monitor just says no input signal. Any ideas on how to fix it before my husband throws it out the window?????
Constant beeping when you turn a computer on is an indication that you have a RAM memory error. To confirm this, open the tower (after unplugging the unit and pressing and holding the power button in for 10 seconds to confirm there's no charge left). Locate the sticks of RAM memory and remove 1. Then plug the unit back in and reboot. In most cases, the beeping will go away and the machine will boot up. This doesn't usually mean you have a bad RAM memory module, just a bad "bank" on the motherboard. If you like the machine, and removing the RAM works for you, you can either run minus the stick of RAM (the machine will be slower) or do a motherboard upgrade. You can usually get a good motherboard + CPU upgrade in the $90 range. Choose a motherboard that will accommodate the existing RAM memory to keep the project cost effective.
Sep 06, 2011 | HP Computers & Internet
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
Property Value Manufacturer VIA Technologies, Inc. Product Name KM266APro-835 Version Serial Number Machine Type AT/AT COMPATIBLE Infrared (IR) Supported No DMI System...
Have you tried enabling onboard sound in the bios as previuos owner may have disabled it if they had a sound card installed.The driver is at Via website......
http://www.viaarena.com/Drivers.aspx
Aug 02, 2009 | Biostar M7VIG 400 Motherboard
Emachine W3107 desktop sound driver
if this is the correct Motherboard in case try the driver
Chipset
Description NVIDIA nForce chipset and network drivers for FIC K8MC51G motherboard File Type Original Driver Version 50.0 Operating System Windows XP Read Me File Download Driver File
other option is go to Nvidia motherboard search an let it find correct driver for MCP51G
Download (35.50 MB)
Jun 21, 2009 | E-Machines W3107 (RBW3107) PC Desktop
Biostar 945P-A7A motherboard: How do I replace the CMOS BATTERY?
I do know that the flat shiny side of the battery (+) is always up....and I've never known a mb to require 2 lithium batteries..
Apr 29, 2009 | Computers & Internet
Emachine T3828 power switch connection to motherboard
The "Ultra Helpful Instructions" that Emachines provide (here: http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf) state that when replacing the system board, "18. Attach all cables to new system board", but fails to say where that would be for each cable.
The site below says it's a genuine Intel board in there, so, congrats on that. http://www.e4allupgraders.info/dir1/motherboards/socket478/D845GVSR.shtml
And with that, the link to the manual:
ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
You're looking for the info on page 32, I believe.
See if that fixes it up. If not, post back.
Jan 03, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Does the motherboard for the model w3107 e machine with the sempron cpu processor driver upgrade deemed compatiable
The AMD Sempron 3100+ Processor is the highestspeed CPU you can run in the W3107 E-machine. No there are no drivers that need to enabled.The system bios sets up the cpu. Did you install this CPU?
Your E-machine:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W3107
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
243 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
