Question about Haier HLC15R 15 in. LCD TV TV/DVD Combo
A dvd is stuck in the Haier tv/dvd combo - Haier HLC15R 15 in. LCD TV TV/DVD Combo
    Guru:
  • 2,178 Answers
Disconnect power and then re-apply. If the disc doesn't come out, then the drive either has a bad drive belt or the eject motor is bad - it'll need to be taken apart to fix.
Posted on Nov 08, 2010
Cant get menu trying to add new remote stuck on dvd
you should be able to control all this from the front panel. If not you can go to the haier website and order a new remote for your device.
Mar 06, 2015 | Haier 7in Ws Digital Lcd Tv dvd Combo Spkr...
Dvd on tv/dvd combo doesn't work on fairly new haier tv
Dvd players don,t use (Heads) They have a (Lazer) Eye, The tray was probally Knocked out of (Alighnment) End needs to be Adjusted.Or with Haier from my expierance with there stuff,Its like a (Disspossiblle) Liter or (Flashlight) Once they Quit working fire it, The drive motors in there (DVD) Players don,t last to long.,I have seen some only a month old where the drive motor burnt out on them.
Oct 02, 2012 | Haier HLC15R 15 in. LCD TV TV/DVD Combo
Haier HLC19 stopped working after a storm
Look for loose contacts in power outlet. If that is ok, the TV might need service.
Aug 22, 2012 | Haier HLC19W TV/DVD Combo
Dvd is stuck in tv/dvd combo
here you can mess the unit up completely if your not carefull,,some of the many different types of system unit have a small hole on the door itself,carefully power on then push a straightened paperclip into this hole,,if you can find one that is,,your only other options would be to use a very flat knife and try to time pressure on the door in conjunction with the power on button the door itself is ,or can be operated by internal cog mechanisms which can break easily--good luck--Davey
Jun 18, 2012 | Haier HLC19R 19 in. LCD TV/DVD Combo
I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
I just bought this TV. It seems a bit out of focus using FIOS tv service and the dvd player. Any suggestions?
Try carefully disconnecting and reconnecting your connectors between the dvd player, tv set and fios box.
Aug 11, 2010 | Haier 20" TV/DVD Combo
I keep getting a no support disc message. my tv is not 2 months old yet
This should still be warrantied.Most TV's have at least a 90 day.Here is the link to Haier.
http://www.haieramerica.com/en/support/contact_form
If you are in Canada or Latin America,there are options at the bottom for that. Good luck! Greg
Aug 10, 2010 | Haier 20" TV/DVD Combo
Dvd won't play
The following suggestion may or may not fix your DVD reader.
You can put a CD/DVD cleaner disk to put into your TV to clean the laser’s eye. The best cleaner disks have the “whisker” that protrudes from the disk and have a fluid you put on the whiskers to aid in the cleaning. Read the cleaner’s directions before using.
You will want to put this disk in your TV at least at three different times to maximize the cleaning.
After you have completed the cleaning, unplug the TV for about 3 minutes. Plug the TV back in and try a non scratched DVD in your TV to see if the cleaning has fixed your problem.
If the TV takes a long time to read the disks and or the TV is not able to read the disks, then the DVD assembly has failed. You could purchase a replacement DVD assembly and install it yourself if you think you are up to it. You just have to remove the stand, the back of the unit, and the old DVD assembly.
I hope this information has helped you.
Good Luck.
May 28, 2010 | Haier HLC26R1 26 in HDTVReady TVDVD Combo
We are finding problems in tuning in to a video game on our Haier tv/dvd. We have tried av1 av2
Either the cable you are using to connect with or the jack that the cable is plugging into on the tv. can you try the video game on a different tv to see if it works? otherwise, i would try a different cable first.
Jul 11, 2009 | Haier 20" TV/DVD Combo
Dvd does not play need help.
u have a off brand tv set that will not get and parts to service it go buy a cheep dvd player for $29.00 at walmart i know u dont wont here this but it is true when u buy the off brands llike the one u have u donot repair them u just go buy another one sorry i hpe this helps u
Oct 13, 2008 | Haier 20" TV/DVD Combo
Haier HLC15R 15 in. LCD TV TV/DVD Combo Logo
291 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
