Question about Casio Watches
Change from 12 to 24 hours - Casio Watches
  • 8,197 Answers
May I get the make and model # to help you more
Posted on Nov 08, 2010
How to change time.
just set the time an hour in front of or an hour behind the time of the day
so if you want EDT then set it back one hour if the current time is 9am to make it 8am
that would make it EDT itme
May 21, 2015 | Watches
How to change hours
Timex Watch setting
Make sure you are in the hour/minute/second mode. Press "set" -- the seconds will flash. Then press "mode" again and the right minute number will flash. Press "mode" again and the left minute number will flash. Press "mode" again and the hour will flash. Press "mode" again and the month will flash. Press "mode" again and the date will flash. Any time any groups of these numbers are flashing, you can change the numbers by pressing the "start/stop" button. When you get the numbers you want, press "set" to lock in those numbers.
To change from 12 to 24 hour, get the hour numbers flashing and press
"split/reset." Then press "set" to lock in either 12 or 24 hour time...
Mar 14, 2015 | Timex Indiglo Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Xinjia xj-686 change to 24 hour mode
Change time. It will alternate between 12 hours and 24 hours.
Apr 02, 2012 | Watches
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
How to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Feb 01, 2010 | Watches
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
Armitron Watches
From the time telling mode press the set button the seconds will flash.
Press the mode button the hours will flash
Press the adjust button to change the hours
Press the mode button the minutes will flash
Press the adjust button to change the minutes
Press the mode button the month will flash
Press the adjust button to change the month
Press the mode button the date flashes
Press the adjust button to change the date
Press the mode button the day flashes
Press the adjust button to change the day
Press the set button when done.
Mar 11, 2008 | Watches
Watches Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
