Question about Acer Aspire 4315 Notebook
Windows cannot access the specified device, path or file.
Everytime I try to Open new application or new installer icon, I cannot open them by have warning box as " Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item" .
Hope u can solve it and tqvm.
  • Tey2 Jun 20, 2008
    Tq iQbal
  • 655 Answers
Try to using Admininstrator user and passwor or the user id and password which have preveleges.
Thanks
Iqbal
Posted on Jun 16, 2008
I cant open yahoo messenger..so i uninstall it and then tried to download it again, but why i cant still open it..there is a error message....its says "Windows cannot access the specified device,path,...
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 21, 2011 | Yahoo Messenger
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
Cannot open specified file. Appears when trying to
It seems the application which needs to open that file is not installed in your system. First check what type of file it is and then install the application which can understand that file.
Nov 12, 2009 | Computers & Internet
Windows cannot access specified device, path, or file... app perm
sounds to be a bug in the system
ensure the program is working, goto system restore and turn it off
turn back on again, this will remove all the old ones, they could have the bug in them,
create a restore point now, then download "combofix.exe"
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
run this
it gives a report when finished, the top section shows deletions, this is the stuff it found
Nov 12, 2009 | Dell OptiPlex GX260 PC Desktop
I just downloaded SM9 and when I try to open it up
If you're using vista the user account control may be blocking you, try right clicking on icon and select run as administrator
Oct 15, 2009 | Iolo Technologies System Mechanic: Windows
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item
It is simple ...... u got to be an administrator to install any software ..or you should be given Rights to Install any thing in the machine ...
Till then u will recive this msg on the screen
Apr 23, 2009 | Computers & Internet
Nothing is opening on my laptop
hi, you may be using windows XP with NTFS file system.
some body/virus has redused the file permissions in your system. Scan the system with an updated virus scanner.
thanks
Aug 16, 2008 | Toshiba Satellite A135-S2386 Notebook
Acer Aspire 4315 Notebook Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
