Question about Canon PowerShot A560 Digital Camera
My Canon claims that I need to change the batteries. However, I have changed them out 3 times with brand new batteries. It is now dead and won't turn on.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 97 Answers
Here is the suggestion:
The battery compartment cover and the design of the metal electrical contacts is flawed. These acontacts re made of springy metal, but there isn't enough force to press the metal securely against the battery. The end of each contact has a metal tab that prevents it from being bent further out to increase the tension. These contacts are the cause of the low-battery warning.
Some fixed the camera by inserting tiny pieces of plastic foam (i.e., spongy, like from "foam rubber" pillows) under the metal contacts. Used a small screwdriver to gently bend up each metal strip, and stuffed a small piece of foam under it. This provides enough force to keep the contact securely touching the battery.
or You can also try the "toothpick trick" as described in various forums, and it seems to be working. There is a belief that there is a design flaw with the battery compartment door, or the springs that press against the battery. By wedging a toothpick under the battery contacts, it seems to force the contacts into the battery, seemingly helping with the problem that many are facing in this and other forums.
Posted on Mar 09, 2011
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
Apr 18, 2011 | Canon PowerShot A495 Digital Camera
My canon A710 says it needs batteries no matter
My A710 did exactly the same thing. Spoke to Canon support. According to them you have to use Canon 2500 mah batteries (quite expensive - need a different charger as well). I've just bought new rechargable batteries from Sanyo (Eneloop pre-charged). And it solved my problem. I've also changed the batteries quite a few times and it never worked. But this did solve the problem for me.
Nov 04, 2009 | Canon PowerShot A710 IS Digital Camera
Canon A470 The date and time menu keeps popping up every time I switch on the camera despite setting the date and time.
There is another battery next the the AA battery under a little cover marked CR1220. That is the battery size. If that battery is dead, or has never been installed then every time you change the AA batteries the camera will forget the time and date. Try to get one from a specialty store that turns over its inventory quickly and you may find that you will only change this battery every 2 or 3 years.
Oct 31, 2009 | Canon PowerShot A470 Digital Camera
My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jul 16, 2009 | Canon PowerShot A75 Digital Camera
Change battery message
I am experiencing exactly the same problem with my Canon Powerhot S2IS. I tried the same thing to remedy it by cleaning off the contacts, but no luck. And it's not simply a cold weather problem. My camera does this with brand new Duracell batteries as well as with freshly recharged NMH batteries. What gives? I've had the camera for nealy 2 years and have taken excellent care of it.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A560 Digital Camera Logo
1,275 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
