Question about Verbatim STORE-N-GO (95312) 8 GB Hard Drive
My computer wont recognize my flash drive - Verbatim STORE-N-GO (95312) 8 GB Hard Drive
  • 12,061 Answers
Ok, well when this happens it can be for a few reasons, the first thing to do though is remove the drivers for it first, then try it again... It may need to be Formatted first, but try this below first.
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Now if you still have problems, you need to try the drive on another, any other compatible PC, and see if that PC picks the drive up.. If it does, then format it on that machine and then try it on again in your PC, and you may now find it is OK.
Unfortunately though these flash drives, will fail, with no warning and for what seems like no good reason, usually they get "Spiked" inserting and removing from the PC's USB slot. One should always use the Safely remove hardware. when dismounting any USB device...
Posted on Nov 08, 2010
    Scholar:
  • 118 Answers
Hi, Please try different usb ports and also check if any other flashdrive is working well in the same usb port (WHERE YOU TRY TO CONNECT YOUR VERBATIM). This will isolate whether its something wrong with the usb port or the flash drive.
Please let me know if you need more help. Thank you:)
  • Verbatim Master
  • 27,725 Answers
Control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
hope this helps
  • Brian Sullivan
    Brian Sullivan Nov 08, 2010
    try blowing all of the dust out of your computer as dust causes satic which causes lots of problems to a computer using a high pressure blower from a compressor making VERY sure there is no MOISTURE in the air lines
How to Repair USB Flash Drives Broken, Unrecognized, Not Detected?
hi Jhon.
this is all i could find out.
Navigate Control Panel -> System -> Device Manager -> Disk drivers. 3. Find and select your USB device, right click and first choose "Uninstall" and then choose "Scan for hardware changes" to refresh the drivers. After all the operations, you will find USB not recognized issue is fixed and the flash drive is detected.24 Jun 2016
Repair & Recover USB Flash Drive not Recognized or Detected ...
https://www.easeus.com/resource/usb-flash-drive-not-recognized.html
How can I fix USB device not recognized?Method 4: Reinstall USB controllers.Select Start, then type device manager in the Search box, and then select Device Manager.Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...Once complete, restart your computer. Your USB controllers will automatically install.Error: "USB Device not recognized" when you try to access a USB ...https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces...Search for: How can I fix USB device not recognized?
how to repair usb flash drive not recognized Google Search
Nov 30, 2017 | Electronics - Others
I just purchased this flash drive, a green case, and when I plug it in my computer will not recognize it.
did you try to plug it in other computer..some of the computers needs some of the drivers so that if you try to plug a device on it..and recognize that you have the driver in your computer otherwise if the driver of your flash drive didn't recognize of your computer..try to search it to your computer if it has on your computer..if not try to search the driver and install it in your computer.
Sep 15, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do i reformat a data traveler kingston 2 gb usb flash drive? i tried formatting but it shows that it is Chipsbank usb flash drive with only 8 mb memory and then it wont complete formatting when i...
Are you positive there isn't a flash drive stuck in a USB port somewhere else on the computer? Very peculiar for the computer to be recognizing a completely different device.
May 18, 2011 | Electronics - Others
It wont recognize my usb flash drive on any computer. it use to work and its not that old
Plug in your flash drive and browse to administrative tools, found in the control panel. Select Computer Management and the Disk Management. Find your drive in the upper or lower list, right click, and re-format. This has been the most effective way to resolve this issue in my experience.
Feb 26, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
All of a sudden no computer will recognize the
These drives do die from time to time. If a comp wont see the drive....it's dameged ...sorry. :(
Feb 19, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
One of two USB drives wont recognize anything
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Dec 13, 2009 | Toshiba Satellite A205-S5804 PC Notebook
Was Dragging Files Onto My 2GB Flash Drive And It Stopped Working
This story may give you hope.
This very same day, I removed my Cruzer Micro unsafely and it stopped being recognized by the computer. I plugged it into another USB port and it did not work. I tried to access it under Ubuntu Linux: I could see the drive but if I click on its icon, I get the message Unable to mount volume, no media.
I tried to reinstall the SanDisk LaunchPad, but it refused to be coaxed because it did not recognize the drive as a SanDisk.
I mourned may drive, but still had hope to recover my data. A google search took me to some data recovery company, that would charge close to 300 dollars. I had no intention of paying that kind of money.
Then, without any particular reason, I plugged the drive in a USB hub that I connected to one of the two ports that failed to recognize the drive. And the miracle happened. Windows recognized it. Was it the presence of the Hub? I don't know.
I made haste to transfer my data to a folder in my computer.
After the transfer I installed the LaunchPad I downlowed from SanDisk. It warned me that my files will be lost. But since I already transferred them, I could not care less.
When I reaccessed the drive, my files were still there. Now my drive works fine: it is recognized by Windows, as well as Ubuntu.
The moral of this story is don't give up easily, and keep trying.
What do you think?
Aug 25, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Usb is not recognizing sansa
try going to "my computer" on your desktop and it should show an unkown device thats plugged into one of your drives
Aug 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Wont read information
Does the computer recognize the flash drive?
Let me know
Thanks
Kevin
May 30, 2009 | Gigabyte Computers & Internet
Computer wont recognize usb drive
try to use another connector! and try connecting it to other USB ports!
Dec 06, 2007 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Computers & Internet Logo
261 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
