Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
I have a mitsubishi ws-65315 tv. I am trying to make it so i can watch tv(i have no cable or dish) in HD. I have tried hooking the antena straight to the tv and tried a digital converter. is there a way to do this?
  • 10 more comments
  • mpic504 Nov 09, 2010
    yes, i use to have a 52 inch rca that if i just hooked up the antenna to i got an hd signal where now i cant get any channels at all on this tv when i hook the antenna up. I get channels using my converter box but in 480. on my old one i had to switch to digital to pick the channels up on the tv but i dont see that option on this one. Any ideas?
    you mean just not enabled for the antenna? because i hook up my xbox in hd and it works perfectly with a great picture. what would i use an sd hook up for or connect it to in order to get hd?
    no it does not have an sd9 component for input/output. so i need a converter box that is s-video compatible to get hd? if so any idea where to get one of those?
    i googled it and can't find one.
    antenna rf in,tv rf out,then the standard red white and yellow video and audio outs.
    also, when i use to get an hd picture it was without the box. it was by just attaching the same antenna i have now directly to the tv.(in case my previous statement was confusing) :)
    did you receive my response?
    rf antenna in,rf tv out,and standard red white and yellow rf outs
    okay, so all i need is this box and an hdmi cable then? and just connect the hdmi cord from this directly to the tv then and it will work? where does the antenna come into play then?
    okay sorry, one last question, which ones on the new box do the red white and yellow go into? i see red,blue,green and a yellow on the back
    yeah i looked around for the connections but havent found anything yet. sounds good though. thanks again for your awesome help i appreciate it!
  • 4,889 Answers
Let me make sure that I understood your question. You want to watch the signal coming from your antenna on your tv in HD? Please clarify the info so that I can tell you how to proceed.
Posted on Nov 09, 2010
  • 7 more comments
  • eagle338
    eagle338 Nov 09, 2010
    That is because this tv is not HD enabled. You either use component or S-video. You cannot used HD on this one. I have just checked the specs once again to confirm.
  • eagle338
    You said you were using a digital converter. Does it take an SD9component) signal as input and output HD?
  • eagle338
    Sorry I meant to say SD(component). Its not SD9. What inputs does the converter have and what outputs?
  • eagle338
    Ok. In that case you are gonna need a component to HDMi converter. It costs you 90$
    http://www.hdtvsupply.com/component-to-h...
  • eagle338
    Yes. Antenna to your converter. Converter's component(White red yellow connector) out to this device's component input. HDMI out to tv's HDMI in.
  • eagle338
    Waoh! That is component RGB video. Sorry about that. Hang on I will find you another.
  • eagle338
    Found one, but its out of stock. We are looking for something like this(scroll down to the bottom of the page)
    http://www.chinavasion.com/product_info....
  • eagle338
    be you can try getting one at radioshack? I will keep looking in the meanwhile.
  • eagle338
    You are welcome. I will post the link as soon as I locate one. If you are going to radioshack look for RF-HDMI converter as well. That should also do the trick.
Cant get mitsubishi ws-63313 to go into hd
Call Dish back. Your HD signal has to be configured in your dish receiver. They can configure it for you over the phone. If not, then the dish guy has to adjust the wires at the splice box wherever it's located in your house. HD requires a dual cable line from the dish to the splice block. It's not the TV.
Feb 21, 2013 | Mitsubishi WS-65313 65" Rear Projection...
Can I hook my laptop to my WS-65315 TV
I do not see any way unless you can outfit a connection to one of the rear inputs---this set was never designed for this type of use so aspect if connected would likely not be useable.
Nov 03, 2012 | Mitsubishi WS-65315 65" Rear Projection...
I am having a problem trying to hook up a ps3 slim with a hdmi to dvi cable to the mitsubishi ws-65315. no picture
try to go to the ps3 settings then go to video output settings , then go to hdmi and it should go black for a min. i didnt think it was working for mine then i unpluged it and there was a big diffrence but it should work
Apr 20, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a Mitsubishi hd 1080 tv and am trying to use it as a monitor for my computer. I have it hooked up but can't get it to show on tv. Any suggestions?
Looking at same problem. No answer yet. Must be device driver (at least for me). I can see the pre-Windows boot up sequence, but frags at Windows. Looking for device driver.
Jan 10, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a tv model # WS-65315. I would like to know if I can hook up a Blueray player and still get HDMI quality?
No, your tv is strictly a Standard Definition one. Even it can receive a HD signal, it is downscaled internally to SD so the image would look exactly like from a low quality dvd player (that's because the internal converter is a cheap one) For best image quality use the converter from the BluRay and the Component connectors.
Nov 29, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Hoe to set my tv to hd
You don't set your TV to HD, you connect an HD source to it via either a component input or HDMI or DVI connection. I fyour TV has its own HD tuner, then you'll need to connect a good antenna or cable system to it.
michtech
Feb 19, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
