Question about Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
We use the Ricoh Aficio 2015 and since the electritions left this morning (after switching off electricity for an hour) we have lost the Fax and Scanner functions. Even in the menu the system setting/gereral features there is no areas to adjust any settings for them. Last week there was!
Help!
Thanks in advance..
Ciaran
  • Ciaran_C Jun 17, 2008
    Good to know, but unfortunately the problem still exists. Thanks for the suggestion IFIXU2.
  • Ciaran_C Jun 18, 2008
    Update, we had an engineer out and it seems the controll board for the fax and scanner has blown due to the electritians not powering down before they knocked off the power in the building.
    Super!
Printing problem main print shado in print lightly
Posted on Jul 12, 2008
    Novelist:
  • 158 Answers
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Posted on Jun 17, 2008
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Hello, I have a problem with RICOH Aficio 2015.
look check that motor bottle is rolling and toner home place is sending toner to drum
Mar 23, 2011 | Ricoh Aficio 2015 Copier
I need to get a meter reading from my Ricoh Aficio 2015 but I am not sure how to do that.
touch the 123 button top left of the screen if i remember then counter option
Nov 04, 2010 | Ricoh Aficio 450 Copier
We have lost our user manuals for the Ricoh Aficio 1015. I need to know how to enter new numbers for the fax directory. Can you remind me how to do so?
I can't remember off the top of my head -- it's in User Tools, either under System Settings and then Address Book, or under Fax Settings. But you can download the manual here, and it will tell you:
http://ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
May 17, 2010 | Ricoh Aficio 1015 All-In-One Laser Printer
We want our ricoh aficio 2015 as a network printer what type of interface we required?.
first u have to purchase feature expantion or GW board from ricoh if it has been already installed in d machine just download the rpcs driver from www.ricoh.com
and install to ur pc
Apr 21, 2010 | Ricoh Aficio 2015 Copier
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Mar 02, 2009 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
205 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
